ryans ROVER
so after doing the cv joint replacement job that i have been putting off for so long i decided to bleed my brakes...after the cv job i noticed my brakes stopped working...im guessing its the brake light switch but idk, im going to test voltage to the lights tomorrow...about the brakes, i cant get good pressure to them...if i pump them once or twice it gains pressure instantly afterwards but the next time i try to brake i must pump the pedal once or twice again to have good pressure to stop..any ideas on what this could be?
ryan mura 1994 range rover county lwb -BIG BLUE 3" coil spring suspension lift -Procomp ES3000 shocks -custom snorkel -glasspack exhaust system -285/75/R16 all terrain tires -old school CB radio from the 80s-cobra -speakers loud enough to set off car alarms -LR3 side air vent |
LOL! I agree with p76, bleed them again! I'll never agree with him again.
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done." |
There is a specific procedure for the bleed. If you don't follow it you won't get it right. Read your manual. I know, I know, reading is hard. I hate to read my manual also.
If you don't have the procedure let me know. |
Ian Matthews
There are certain safety aspects of a motor vehicle that you should not play with unless you know what you are doing. Brakes is one of them. The first couple of times you should get someone that knows what they are doing to help you.
I assume that the Rangie in question has ABS. This adds further complication to the task and you can esaily stuff up the ABS unit if you don't know what you are doing. A relatively simply job of changing brake pads can cause the ABS unit to fail if you don't do it correctly. So my recommendation is not to read a manual and don't try and do it yourself. Take it to someone that knows what they are doing and watch and ask questions. Then maybe have a go next time if you are feeling confident. |
![]() Join Date: Dec 2005
I agree with the guys, read the manual and seek someone with brake experience to assist you. When I did brakes on a friend of mine's truck and ended up bleeding all the way round, we found there was a special way of doing it, and by following the steps, we bled the system and got r' done. On a Rover system, especially that of ABS, requires a very sophisticated brake bleed procedure, so follow the manual.
ryans ROVER
ok well i got the brakes done and working good...i was just trying to figure out why my brake lights arent working, i tested the current to the bulbs and their was none..would this be a brake light switch problem?
It was on mine.
![]() I think I have a write up on that on my site. It was about 2 years ago, I think. I went and looked. NOPE. Never finished writing it up. It's no big deal though. |
