Links
Old 05-08-2008, 01:27 PM   #1 (permalink)
Default Brake Line Replacement
So I'm getting a 2 inch Rovertym lift in a few days and will be doing it myself. Since I was already getting rear brake lines, I figured why not replace the front ones while I'm at it. I want to know if there's any special steps replacing the lines or if it's straightfoward, also the best way to refill the brake fluid into my system (1995 RRC with ABS)? I was just looking for any tips you guys could contribute. Thanks
FoCoRRC is offline   Reply With Quote
Old 05-08-2008, 01:32 PM   #2 (permalink)
It's not broken, it's just not fixed yet.
Beard's Avatar
if your talking the hard lines?
they rent the proper tool if you wanna do things kosher
Where to buy brake line, fuel line, brake line flaring tools, brake line nuts and brake line fittings
Project Rover Page
Beard is offline   Reply With Quote
Old 05-08-2008, 01:35 PM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
It's a straight swap. Just follow the bleeding procedure. I'm guessing you got longer ones due to the lift.
I had my lines made at a local shop and had them made 2 inches longer.
I punch my clown daily.
Old 05-08-2008, 01:36 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
TRON!!!!!!!
Awesome.
2.25 diesel engine fuel priming after line replacement archaeology_student Series Land Rovers 4 02-13-2008 12:49 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
help! motor running on brake line system jb1rd Discovery Series I 3 05-14-2007 04:47 AM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
