Old 12-28-2006, 09:17 PM   #1 (permalink)
Default Brake Pedal...weird vibrations when pushed
Hello all,
Has anyone had a weird vibration from the brake pedal and would you know what the first place to look for the cure is? It even makes a little buzz sound too.
I have a 95 Classic County SWB.
Thanks in advance!
boxer is offline   Reply With Quote
Old 12-29-2006, 04:45 AM   #2 (permalink)
It sounds like your ABS system is kicking in. Under what circumstances does the pulsing come on? Also, the buzzing sound is your ABS pump. Does it run for a very long time when you first start the truck?
