Hey Wayno. The bleeding part is pretty straight foward. You don't need anything special to do it on the RRC. I did both of the main lines running from the abs actuator to rear axle junction without any problems. I just ordered a hard pipe kit from Jeg's so that I can replace both hard lines on the rear axle and have spare brake lines. Good luck.
Abraham
2000 Discovery II SD
1993 Range Rover County LWB
I run, play, fix and live Rovers because I choose to.
