Old 02-05-2008, 10:38 PM   #1 (permalink)
repete's Avatar
Default broken classic
So my 93 got a ride on a flat bed today! when I pulled into a gas station, my wheel jerked a bit. after filling up, I pulled away and wheel jerked a good bit more and then BANG somthing snaped and no power! In gear ,the front prop shaft spins, so Im guessing its in the pinion. Any ideas?
repete is offline   Reply With Quote
Old 02-06-2008, 04:09 AM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
Should have still driven if something in the front or rear went. So indications are that it is something in transfer case or transmission.
Old 02-06-2008, 05:30 AM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I would think it's something in the front end I don't know that the vc would lock up in that case so the TC would just play the role of a open diff sending all the power to the point of least resistance. I may be wrong though wouldn't be the first time.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 02-06-2008, 09:49 AM   #4 (permalink)
repete's Avatar
in theary, if everything was working properly, i could pull my front shaft and still be able to drive/move the truck on its own power. could it be that rear portion of my t/c failed, thus causing eccessive load to my front pinion and snapping it?
Old 02-08-2008, 06:06 PM   #5 (permalink)
1989 county 3.9
despite the fact that it won't go any where can you shift it... did you put it in neutral to put it on the flat bed, maybe its just slipping from no atf?
MysteryTheatre is offline   Reply With Quote
Old 02-08-2008, 07:56 PM   #6 (permalink)
94 Defender 90
cellulararrest's Avatar
The VC won't let the two propshafts turn at different speeds (only very slightly). If your front shaft is spinning the rear is not you definitely have something wrong with your transfer case/VC.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 02-24-2008, 09:16 PM   #7 (permalink)
repete's Avatar
Thanks all! It wound up being that my viscous coupling failed open, giving power only to the front end. as a result, a week left front c/v exploded and left me callin a tow truck.
All better now.
Update on Re-do of my 1991 Classic interior hermanpj Range Rover Classic 69 02-11-2008 01:24 PM
1995 Range Rover Classic Broken Roto Flex tebelleh Range Rover Classic 4 02-07-2007 12:05 PM
1995 Range Rover Classic LWB w/ NEW engine Serg Land Rover Vehicles 3 11-21-2005 06:33 PM
1995 Range Rover Classic LWB Serg Land Rover Vehicles 7 05-04-2005 12:31 PM
95LWB Classic - winch mounts Jonesy Range Rover Classic 2 10-25-2004 05:40 AM
