So my 93 got a ride on a flat bed today! when I pulled into a gas station, my wheel jerked a bit. after filling up, I pulled away and wheel jerked a good bit more and then BANG somthing snaped and no power! In gear ,the front prop shaft spins, so Im guessing its in the pinion. Any ideas?
Rebuilding Rover
I would think it's something in the front end I don't know that the vc would lock up in that case so the TC would just play the role of a open diff sending all the power to the point of least resistance. I may be wrong though wouldn't be the first time.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
in theary, if everything was working properly, i could pull my front shaft and still be able to drive/move the truck on its own power. could it be that rear portion of my t/c failed, thus causing eccessive load to my front pinion and snapping it?
94 Defender 90
The VC won't let the two propshafts turn at different speeds (only very slightly). If your front shaft is spinning the rear is not you definitely have something wrong with your transfer case/VC.
Thanks all! It wound up being that my viscous coupling failed open, giving power only to the front end. as a result, a week left front c/v exploded and left me callin a tow truck.
All better now. |
| Thread Tools | |
| Display Modes | |
| Update on Re-do of my 1991 Classic interior | hermanpj | Range Rover Classic | 69 | 02-11-2008 01:24 PM |
| 1995 Range Rover Classic Broken Roto Flex | tebelleh | Range Rover Classic | 4 | 02-07-2007 12:05 PM |
| 1995 Range Rover Classic LWB w/ NEW engine | Serg | Land Rover Vehicles | 3 | 11-21-2005 06:33 PM |
| 1995 Range Rover Classic LWB | Serg | Land Rover Vehicles | 7 | 05-04-2005 12:31 PM |
| 95LWB Classic - winch mounts | Jonesy | Range Rover Classic | 2 | 10-25-2004 05:40 AM |
