yo mama
Hey all: Just wondering if anyone knows a little about replacing all the bushings?
Cheers! ![]() |
I changed the bushings on my 88 RR with about 200K miles. Some of the bushings will go faster than the others. Its not a job you want to do often. I used OEM stock bushings. Most guys use the poly bushes. They cost twice as much or more ( I paid $100.00 for a full set of OEM bushes), but they are half as easy to put in. NO matter what you are going to have to have a 20 ton press to get the old ones out.. the poly bushes go in without fight, but the OEM ones need to go in with a press. If you wheel alot you may consider the poly's, But in my personal and humble opinion, the stock ones work good enough for Land Rover to put them in so why not do it again.
What ever you decide from mine and others advice, this is not a job you want to do often! ONCE is enough!.. So make your choice wisely. My 2 cents
Any advice given in this forum is my 2 cents, which is roughly the value of said advice! Dan Hamren 93 LWB "Dubya" AKA "The Beast" |
Series Moderator
Ironman polybushes marvellous,replace bolts when doing it they wear too,avoid stainless inserts will wear bolts at an alarming rate,to remove old bushes use a blowtorch to burn the rubber out then use a hacksaw to cut through the outer casing knock out with a hammer and chisel easy!!
ONz (bushmaster general) |
