Old 07-19-2006, 07:30 PM   #1 (permalink)
Question A/C Compressor not working
Can anyone tell me where the thermostat is for the A/C. And is it hard to get to. My compressor is not cycling with selector set to A/C. I jumped the pigtail under the hood connected to the compressor and it worked and started to blow cold air inside. I located and checked the relay on the firewall and even swapped it out with another Bosch relay. No good. On one of the wires that connects to the relay there is 12v. I am missing the signal to activate the relay. When I applied 12v to the compressor I saw a little bit of bubbles then clear liquid in the seeing glass. Any suggestions are greatly appreciated.
Thanks in advance.
Triple R is offline   Reply With Quote
Old 07-20-2006, 01:16 AM   #2 (permalink)
RageRover's Avatar
What year is your RRC? If it is pre-1994, it may have the old R-12 system, but even so, if you have a 94 or newer, and have the R-134a system, you will have what they call pressure switches on the A/C lines.
You can easily identify them by the two wires that come out of them, and the cylinder shape on the A/C line. Most likely it is bad and causes the Compressor to not cycle.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-20-2006, 05:11 AM   #3 (permalink)
Sorry about that.It is a 1989. I believe the pressure switch is on the dryer. Does the system shut down if the levels are too low? Can you Jump the circuit to test the line or can you test the component itself. Thanks.
Old 07-20-2006, 09:04 PM   #4 (permalink)
gordo's Avatar
On my 89 it is almost always that dang relay you mentioned. I would check the fuses too. Also pull the wire off and check the voltage. More than likely there isnt any. Sorry I cant help more. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 07-20-2006, 10:48 PM   #5 (permalink)
RageRover's Avatar
I agree with Gordo, check the electricals first.
And yes the pressure switch will disable the compressor from engaging, preventing damage to itself and the whole system, if the level of refrigerent is too low.
I wouldn't recommend trying to jump a wire to the compressor to see if it is working with the engine running, but you can try it with the engine off. This will show if the compressor electromagnetic clutch is working. And if it doesn't engage while engine running, of course check the electricals.
Good luck man, I feel the heat of summer already, and I see why everyone wants the A/C to work.
1995 RRC LWB
Old 07-25-2006, 06:39 AM   #6 (permalink)
Thanks Guys..Considering I have cycled the compressor and have checked the fuses I will give a charge of R12 and hope for the best.
Old 07-25-2006, 11:10 AM   #7 (permalink)
RageRover's Avatar
Ok, cool, good to hear man.
1995 RRC LWB
Old 07-25-2006, 03:56 PM   #8 (permalink)
Question
Meant to ask if the switch on the dryer is bad,can you remove without letting the freon out..Thanks
Old 07-25-2006, 05:21 PM   #9 (permalink)
RageRover's Avatar
Unfortunately no, you'd have to evacuate the system and then remove the switch. Then refill the system.
1995 RRC LWB
Old 07-28-2006, 04:33 AM   #10 (permalink)
Dang it..Maybe I will go for the R134 conversion from Atl British if that's the case. Thanks soo much for the insight..You guys rock...
Old 07-28-2006, 12:32 PM   #11 (permalink)
RageRover's Avatar
Yeah, that is usually what some A/C shops will ask you to do if you have the R-12 system, is to retrofit it to R-134a. I still need to retrofit my mom's 86 Benz 420 SEL to R-134a, as the system doesn't even work.
1995 RRC LWB
Old 07-30-2006, 07:45 AM   #12 (permalink)
Bad time to have no A/C. At the rate I am going I'll have it done just in time for the snow.
