Anyone ever rebuild a caliper? I think I need to rebuild the calipers on my 88 RRC. The pistons are binding. How hard is it, and what do I need to do? New calipers are very expensive, so I was hoping there was a better(cheaper) solution. Thanks.
Doug |
#2 (permalink) | |
AutoZone has Calipers for the D1 (1994-1999), I assume they also have them for the RR. On my D1, they ran about $45. A-1 cardone, with a LIFETIME warranty. You swap out the leaking, old, sticky caliper bring it in as a core. They will then credit you back the difference plus you get the warranty. Good luck! Edit no dice at AutoZone but Napa has them....http://www.napaonline.com/masterpage...=3&SubCatId=13
2006 Range Rover Sport HSE Rimini Red 2001 D2 CDL ![]() 1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired) 1988 RRC SWB ('Silver Bullet' Retired 05/98) |
Ian Matthews
You will probably not have to rebuild them, only replace seals and any damaged pistons. They are relatively easy to rebuild. I find it easier to remove the caliper from the vehicle. Use a clamp on the brake lines to stop the fluid leaking while they are off.
I use compressed air to pop the pistons out. You put the air down the holes where the brake fluid goes into the caliper from the brake system. The first piston from the primary and secondary systems comes out easily with air. To get the second piston out you have to stick your finger in where the piston came out and block the small hole at the back. This will direct the air you the second piston and pop it out. But watch your fingers as they can pop out quickly if too much air is applied. Clean out the cylinders where the pistons came from and remove two rubber and one metal ring from each cylinder. Fit new seals. Check pistons for any scoring or wear and replace with new ones as required. Refit everything a bleed brakes. |
Atlantic British carries rebuilt calipers for your truck for a reasonable price. I know, I needed all 4 when I rebuilt my Hybrids brake system.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
![]() Join Date: Dec 2005
I just learned how to rebuild calipers myself, and I find, that if you don't have the money to buy a whole new one, even though that new one has lifetime warranty, that it can save some money.
I saved my roommate quite a bit of money; instead of getting front new calipers, we got the $4.99 caliper seal kit, and I replaced the seals and the car was back in business in no time. Plus, I think it is more interesting to rebuild the calipers, IMO. Saves me money, and just builds experience for me.
#9 (permalink) | |
Doug 61 Series II 109 SW 88 Range Rover Classic SWB 96 Range Rover P38 97 Audi A8 |
