Old 09-02-2008, 06:03 AM   #1 (permalink)
Default cam timing
I pulled the timing cover on my 95 - 4.2L
It looks as though someone in the past replaced the timing chain and gears with a roller set but when the installed it, they had the cam at 4 degrees retarded (you have keyways on the CLOYES chains - 1 for TDC, 1 for 4 retard, 1 for 4 adv). I assume since I have a stock motor it should be TDC right?
Anyways, at 4 retarded on the cam in my current situation the only thing I would have is a loss of power right?
Would this effect idle in any way>???
deadboy1977 is offline   Reply With Quote
Old 09-03-2008, 07:06 AM   #2 (permalink)
only thing i have read is that I will get more power at high speeds, probably no effect on idle
Old 09-05-2008, 01:29 AM   #3 (permalink)
Dutchgit's Avatar
Best try and contact the manufacturer of the timing set for timing settings.
The gear might be on 4 degrees but the chain might be some degrees off in the other direction.
Get the basic settings and start afresh.
Nothing is sure but death and taxes.
Dutchgit is offline   Reply With Quote
How to removed timing cover on 4.0?? Cutlass84 Discovery Series II 4 07-18-2008 06:21 AM
D1 4.0 to Bosch 4.6 switch & timing covers JohnnyDisco Discovery Series I 2 06-09-2006 06:14 AM
Timing the 3.5 without the Timing Marks!! oldad Range Rover Classic 3 10-09-2005 08:39 PM
Timing Chain Breakage Jayce Series Land Rovers 14 08-18-2005 12:18 AM
Timing and Overheating mkerr2112 Defender 3 07-06-2005 03:57 PM
