Old 07-12-2007, 12:45 PM   #1 (permalink)
happytrails's Avatar
Lightbulb Canvas Top Project
i am considering cutting the roof off of my range rover classic and making it a canvas top...kind of resembling a defender . i want the top to be removable and able to still go back on in case of bad weather and winter time.
anyone have any pictures of this done? or even heard of this being done?
i am basically asking you guys to give me your $0.02 on how this can be done. shoot me some ideas and potential problems i may be overlooking. i want this planned before i go out there with a "sawZall" and dismember my landy!
thanks...i hope this is going to work out because i really want it done!!
-justin
happytrails is offline   Reply With Quote
Old 07-13-2007, 04:35 PM   #2 (permalink)
M. Hensley
mensley's Avatar
you can unscrew/unbolt it, y\you shouldn't have to cut. It is clear once you remove the headliner. You may need to have a bar welded in across the b & c pillars for strength.
-Mason
mensley is offline   Reply With Quote
Old 07-13-2007, 04:55 PM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
SCSL did a chop on his D2. Search in the Disco section for the thread, also check over on Discoweb too. Might at least give you some ideas as to what direction you want to take.
Hey did you at least lift that thing and put some tires under it yet????
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 07-14-2007, 10:40 AM   #4 (permalink)
Elephantitis penisitis
Are you talking just the roof or the sides too? The roof is held on by rivets. You can punch out those rivets and use screws to put it back into place when you want. If you are talking about cutting the sides too, have a roll cage built for safety and then make a bikini top that snaps to the roll cage. As far as putting the top and sides back on during inclement weather... good luck with that and let me know what you come up with.
Old 07-14-2007, 05:01 PM   #5 (permalink)
I've taken off about a dozen roofs, SWB's, LWB's, w/sunroof, w/o sunroof, NAS, non-NAS and none of the roofs were secured with rivets. They all had roughly forty screws/bolts securing the roof.
Basically, if you have a weekend to kill and a friend to help, you could easily remove the roof from your Range Rover to see how you like it. It would also be a great time to redo the headliner if yours is sagging.
Naturally, if you want a really clean look you'll need to remove the B and C pillars between the windows along with the rear pillar. At that point some sort of roll bar would be useful not just for safety but I would imagine it would help with body rigidity.
There was someone on Dweb who removed the top on his RRC. He did a nice job and even sealed off the rear doors making it a two door with side facing rear seats. Go on over there and do a search, it wasn't that long ago.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 07-15-2007, 10:54 PM   #6 (permalink)
If the roof is going then you need a roll cage of some sort. Safty Devices makes cages for RRCs. For a custom top a good place to try are Marine upholstery/Hot Rod/Custom car specialist shops in your area. Any of these types of shops can make up a hood for your Rover any way you want it, as long as you have the dough! Is the truck going to be a poser or a off roader? The reason I ask is if you are going for off road capability and removing the roof anyway you may want to look into giving your Rover a bobtail while you have the sawzall out! Whatever you do be sure to take a few pic's and show us the results.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Old 07-19-2007, 12:56 PM   #7 (permalink)
no...no lift yet but i have some a/t's! its a start lol.
its looking like i'm going to have to get the cage for my idea to be effective...and make the most sense. i'll keep you guys updated...some other things need to be knocked out before i start on that.
THANKS A TON FOR THE INPUT!!!!
-justin
