True. The only thing I'm going to be concerned about is getting fuel through the carb on steep angles. Do you know of any "off-roading" carbs on the market?
Its not the most fuel effiecent, yet very simple system to work on and somewhat fairly reliable!
I'm curious....why the heck would you want to do a swap like that!
I have an '83 RR that was converted to EFI.....and a '93 LWB 4.2 and besides changing wires and dis. caps and plugs, Have never had any issues in like 13 yrs.!
If your serious. I have the buick four barrel manifold edelbrock 650cfm carb and some other odds and ends ill send you for 350. Carb is new only ran on mine for a few days now I'm swapping to a bmw power plant and have no need of it. Let me know.
Because I've spent the last year and a half tracking down a horrible misfire issue, and replacing everything on the system, and it's still there. Quite frankly, after the grief lucas had given me, I hate fuel injection. Way too much to go wrong. I'd rather just keep it simple with a good old carb.
what makes you think that the misfire is caused by a fueling issue? Could just as likely if not more be an ignitioni issue and switching to a carb won't solve that. switching to a carb seem very counter productive especially with your concern of fueling at steep angles.
Why?
Parts replaced:
Spark plugs, ht leads, rotor, cap, ignition pickup, ignition pick up module, distributor, throttle posistion sensor, maf sensor, stepper motor, coolant temp sensor, fuel temp sensor, o2 sensors, fuel pump, fuel filter, injectors, fuel pressure regulator, ECU, and coil. Other than that, no reason.
Yes, definitely stay under 500 CFM for the carb and make sure you set it up correctly.
The effectiveness and reliability Lucas 14 CUX EFI system over a carburetor is seriously overrated.
...and as far as a carb giving you problems at steep angles.....a Lucas 14CUX can give you problems at any angle.
It's Achilles heal is the fact the system is a retrofit onto an old engine designed for carbs and the very poor quality (by today's standards) sensors all OEM's used back then. Add twenty years + multiple owners throwing parts at it and you get all kinds of running problems. Some of the most often questions asked on the forum are poor running/EFI related.
A Carb is hard to beat for field diagnosis, repair and service. Especially if you take your Rangie on extended trips into the bush.
LUCAS EFI has it's supporters...........but I'm not one of them.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Finally, somebody who speaks English! I'll have to do more thoral research on the matter, but I'd take 2 less mpg over being stranded in the bush with a busted stepper motor any day of the week
