Carb Swap - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 30 (permalink) Old 01-13-2013, 10:41 AM
roverandom's Avatar
Quoted: 2 Post(s)
That 2mpg hit is a worst case scenario, usually quoted by folks comparing the figures with the optimistic factory numbers of a stock vehicle when new.
In any case, once you average out the days that the EFI gives you 6mpg because of faulty sensor readings or plugged IAC, you will most likely save on gas in the long run.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #17 of 30 (permalink) Old 01-13-2013, 05:54 PM
Quoted: 0 Post(s)
Swap in a bmw m20 and call it the next ten years of no headache efi lol that'sy plan anyway. We shall see how it actually goes since I've yet to run across anyone who has done the m20/m50 swap into an rrc. Only talked about it.
I've built an ran many m20b27's never put one in anything but an e30 or e28 but I'm certain they have the torque needed for the job. (Especially in low range) and I have never encountered one with an efi related issue that wasn't easy to diagnos
Sent from my iPhone using AutoGuide.com App
drillerjoe84 is offline
post #18 of 30 (permalink) Old 01-13-2013, 07:16 PM
Rover-Holic and Moderator
ArmyRover's Avatar
Quoted: 11 Post(s)
There is one that is complete and running with the M50 over on pirate4x4.
1972 MGB
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum WWW.Lucky8LLc.com 716-898-8153
Have a DII you need a drive shaft click here http://landroverforums.com/forum/luc...e-shaft-79071/
Want a http://cannibalv8resurrection.com/ best read this first http://landroverforums.com/forum/dis...-beware-78080/
Need used parts? paulgrant@mac.com
ArmyRover is offline
post #19 of 30 (permalink) Old 01-14-2013, 12:14 PM
roverandom's Avatar
Quoted: 2 Post(s)
Old BMW's suffer the exact same fate as old Range Rovers.........namely a once expensive and premium vehicle, requiring expensive parts to repair and service, ending up in the hands of someone under 25 (by the time it has change ownership a few times) with no idea what he is doing and no money to do it properly anyway. Huge amounts of $$ are spent on cool rims and stereo equipment while the rest of the vehicle go's to hell in a hand basket......usually the last stop before the crusher.
I used to work on tons of these and BMW's are no better than any other manufactures version of EFI during the early Nineties.
Matt.
post #20 of 30 (permalink) Old 01-15-2013, 05:36 PM
Quoted: 0 Post(s)
Due to my personal experience with the m20 m30 and m50 engines I would have to call bs on this sorry.
post #21 of 30 (permalink) Old 01-16-2013, 01:28 AM
Quoted: 0 Post(s)
Thanks army rover just found him. Boy an m50 would be nice in there and looks good too!!!
post #22 of 30 (permalink) Old 01-16-2013, 03:01 PM
roverandom's Avatar
Quoted: 2 Post(s)
BS on what exactly? BMW's do not get old? They do not eventually become owned by kids that can't afford to fix them correctly? That I have not, in fact, ever worked on BMW's...........or that the BMW EFI is just as fallible as any other system?
If you believe that these statements are untrue, either your "personal experience" is limited or you been drinking too much of BMW's Kool aid!
Matt.
post #23 of 30 (permalink) Old 01-17-2013, 08:33 AM
Quoted: 0 Post(s)
Carb Swap
BMW efi is far more reliable then that of the older rovers. Plain and simple.
post #24 of 30 (permalink) Old 01-17-2013, 11:19 AM
roverandom's Avatar
Quoted: 2 Post(s)
...and Land Rovers never rust cause they are made of aluminium!
Gimme a break.
Matt.
post #25 of 30 (permalink) Old 01-17-2013, 10:45 PM
Quoted: 0 Post(s)
Carb Swap
Gimme a break.
I think you mean this facetiously but just for clarification they are in fact not made entirely of aluminum..…
post #26 of 30 (permalink) Old 01-18-2013, 05:22 AM
Ian Matthews
p76rangie's Avatar
Quoted: 18 Post(s)
Originally Posted by enterusernamehere View Post
Finally, somebody who speaks English! I'll have to do more thoral research on the matter, but I'd take 2 less mpg over being stranded in the bush with a busted stepper motor any day of the week
I have had both and I would not go back to a carby over an EFI. Actually just ditched the Holley on the ute and fitted EFI. Too may things to set up on a carby to get it to run correctly and they are not easy to adjust. A lot easier to set-up and tune an EFI.
p76rangie is offline
post #27 of 30 (permalink) Old 01-18-2013, 08:48 AM
roverandom's Avatar
Quoted: 2 Post(s)
Yeah, I know. I was being a smart arse.
Matt.
post #28 of 30 (permalink) Old 01-18-2013, 09:20 AM
roverandom's Avatar
Quoted: 2 Post(s)
I've had both too, but I like the carb better.
Maybe it's because I cut my teeth on Series Land Rovers and the tough old 2.25L 4's along with other old British and American iron and I learned about practical carb tuning on the shop floor? A skill that is rapidly becoming a lost art!
Or maybe it's because I've worked on so many Disco's and Rangies of this of age that I have become jaded? Because a 14 cux that is functioning correctly can be a very nice thing. But OEM components are expensive and the jobber stuff is crap quality and not worth fitting.
I know my way around both systems and am comfortable diagnosing problems with either. But for me, a well set up carb is preferable to EFI because it's reliable, easy to maintain with parts available anywhere and it's 100% mechanical design allows it be repaired in the field.
Do I think it's better than the EFI found on the newer products? No, but those systems are vastly improved and have much higher quality hardware and more sophisticated software.........and are not 20 years old already.
My 2c.
Matt.
post #29 of 30 (permalink) Old 03-02-2013, 09:20 AM
1980RR2DR's Avatar
Quoted: 0 Post(s)
Why don't you put twin SU's innit?
1980RR2DR is offline
post #30 of 30 (permalink) Old 03-02-2013, 08:23 PM Thread Starter
enterusernamehere's Avatar
Quoted: 0 Post(s)
A little to finikey for me.
enterusernamehere is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
t-case swap question and LT230 swap, why? rlmfire Range Rover Classic 9 03-08-2011 03:09 PM
carb conversion mrevo0 Range Rover Classic 5 05-04-2010 12:09 PM
Rochester B carb Greg S Series Land Rovers 0 02-22-2010 07:49 PM
carb to snorkel???? cobb ridge Range Rover Classic 1 08-04-2007 12:53 PM
Carb Choices theclay333 Series Land Rovers 9 12-15-2005 02:34 AM
You may post new threads
You may post replies
