» Sponsors
» Sponsors
Old 07-03-2009, 11:17 PM   #1 (permalink)
1993 range rover lwb - Roman Bronze
ehojefua's Avatar
Default center console
I have a 1993 range rover LWB and I am looking to replace my center console assembly. Does anyone know where I can get a good one that has the cigarette lighter in the back. I have tried a rover company in britian and the one they have is not the dual coin tray one and theres is smaller. I am in atlanta GA. Can anyone tell me where to finds one and also is it a pain in the ass to take and put it back together? Any response will be great.
ehojefua is offline   Reply With Quote
Old 07-04-2009, 08:57 AM   #2 (permalink)
Have you seen this one? Looks to be pretty close to the original.
Twin Coin Tray-Range Rover Classic Centre Console Cubby Box Late GRP
Not sure about the lighter in the back.
dano is offline   Reply With Quote
Old 07-04-2009, 10:50 AM   #3 (permalink)
Have you seen this one... OEM RANGE ROVER CLASSIC CENTER CONSOLE CUBBY BOX 87-94:eBay Motors (item 370216255329 end time Jul-16-09 10:14:04 PDT)
Or this one with the fancy cupholders inside... LAND ROVER RANGE ROVER CLASSIC CENTER CONSOLE:eBay Motors (item 330341789980 end time Aug-01-09 00:03:00 PDT)
Kevin
88 RRC "Audrey"
Old 07-04-2009, 07:59 PM   #4 (permalink)
Not intended to hijack the thread, but a related problem....the power window switch panel has come adrift on my '89. Has anyone had this problem or found a solution for it?
Thanks.
Jack
Jack-the-Lad is offline   Reply With Quote
Old 07-08-2009, 12:46 PM   #5 (permalink)
ehojefua's Avatar
Kevin88RRC - thanks for the link. I went to the second link and it all worked out. That is the exactly one that I need with the cigarette lighter in it. thanks.....now I need the left side traffic turn signal, the from left bumper cap, and a new headliner
Old 07-09-2009, 08:19 PM   #6 (permalink)
hermanpj's Avatar
Gallery: 4
Thanks.
Jack
this happens when the piece of the center console plastic which frames the switch panel breaks. then the little plastic tabs on the back of the switch panel have nothing solid to anchor to. take the center console out and JB weld all that plastic back. if you need to you can cut a piece of plastic from somethign around the house and JB weld it into place to make a new backing. i used strips of metal with JB weld and has worked out pretty good.
Pat Herman
Old 07-11-2009, 08:10 AM   #7 (permalink)
Thanks, Pat. I'll give it a try.
Jack
Old 07-12-2009, 05:05 PM   #8 (permalink)
Default Advise on fixing your headliner
I have a '92 County and decided to try repairing my headliner before I bought a new one. The headliner is surprisingly easy to remove and it only took a few hours to peal off the fabric, scrub off the deteriorating foam that backed the fabric and then using some spray adhesive, attach felt as the new covering. You have to carefully trim the sunroof cover to avoid having the cover not slide easily.
The end result looks great, quiets down the car a bit and will never sag since there is no lame fome to deteriorate under the covering.
There are a number of guides available on the net to give you step by step pictures and instructions, but it was done in an afternoon and was easy.
Gelf1907 is offline   Reply With Quote
Center console - rubber mat and window switch panel Chazz Layne Land Rover Parts and Vehicles Wanted 0 02-07-2009 10:31 PM
Center Console BrokeRover Range Rover Classic 8 11-09-2008 11:44 AM
Need Headliner and center console assembly ehojefua Land Rover Parts and Vehicles Wanted 1 10-26-2008 05:51 PM
F/S DI Center Console in Excellent Condition Paul Grant Land Rover Parts and Accessories 0 12-27-2007 02:54 PM
Center console problems sky Range Rover Classic 3 06-22-2005 12:58 PM
