Old 01-25-2005, 11:39 AM   #1 (permalink)
Default center console wood trim piece
Anybody know where I can get a good condition center console wood trim peice for 95 RR Classic?
Mine is faded, lifted and cracked. I checked with Car Cannibal, British Car Services, DAP and no luck unless I buy from dealer new for $500.
Thanks for your help.
AdrianL is offline   Reply With Quote
Old 01-25-2005, 12:28 PM   #2 (permalink)
hamrendan's Avatar
Default You know I had an idea about that
Seeing how its so expensive to replace/repair these things. I was thinking about doing what the Audi guys do. They by carbon fiber weave from guys on ebay, and then cover thier trim with it. You place it on there cut it out and then add resin... after a couple of coats of resin you have that factory fresh racing look. Now dont' get me wrong, I think it would look strange in a Rover too, but it would also look very different, and since the dash is dark grey anyway there would not be a color clash... Anyway thats my thoughts on it..
Dan Hamren
93 LWB "Dubya" AKA "The Beast"
hamrendan is offline   Reply With Quote
Old 01-25-2005, 02:28 PM   #3 (permalink)
troverman's Avatar
There's Atlantic British located in Clifton Park NY. Sometimes their prices can be high, but cheaper than dealer typically. I have used them before. I know what you're saying about the wood piece--Before we bought the 4.0 we tried out several 95 LWB's with the same problems as yours with that piece of wood.
The 4.0 we bought has wood that seems perfect--it is because its just plastic veneer. The Range Rover Classic actually has "real" wood. Virtually no new car makers use "real" wood anymore. There's also Rovers North in Vermont, and British Pacific on the west coast. Good Luck.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 01-25-2005, 03:10 PM   #4 (permalink)
kesslergk's Avatar
Default Ebay
They are sporadically there, usually go for just over $100.
If just the veneer is cracked, you could sand down the piece, and reapply the veneer.
Gordon
Gordon Kessler
1995 LWB
1999 4.6
2002 Disco
Previously owned:
1994 D90
1995 disco 5-speed
1996 4.0
kesslergk is offline   Reply With Quote
Old 01-26-2005, 12:25 AM   #5 (permalink)
ohiorover's Avatar
Default wood trim
All the trim in my 92 was cracked and fading. I tried to remove the old veneer and replace, one word "nightmare" First the old veneer is hard to remove . When you finally get it off the new veneer is hard to form to the compound curves on the edges. After spending a week on one piece from the rear door, I went the carbon fiber route. Just put it right over the old stuff, after sanding it slightly. two coats of clear resin and it looked like a factory job. I found the carbon fiber on ebay, lots of different weaves and looks on there. I used a 4X2 weave.
ohiorover is offline   Reply With Quote
Old 01-26-2005, 06:03 AM   #6 (permalink)
4x4 Adventure Gear
John C's Avatar
Check the For Sale section, there are lots of folks parting out RRs..
Old 01-26-2005, 06:43 AM   #7 (permalink)
kesslergk's Avatar
Default Just remember, '95 has a different dash and center console
Nm
Gordon Kessler
1995 LWB
1999 4.6
2002 Disco
Previously owned:
1994 D90
1995 disco 5-speed
1996 4.0
Old 01-26-2005, 08:02 AM   #8 (permalink)
CoachDitka's Avatar
There are also a variety of interior trim kits on eBay, and some of them are pretty damn good. A friend of mine had an old '78 Mercedes with wood trim that was way over the hill, and he bought a kit for like $125 that covered every piece in the car. They apply with 3M adhesive tape, and if you are careful you really can't tell they are stuck on pieces, and to be honest they looked just about as good as real wood, in fact I could not even tell unless I REALLY examined the things.
-Coach
CoachDitka is offline   Reply With Quote
Old 01-26-2005, 08:28 AM   #9 (permalink)
Default 95 rare spicies for timr piece
I have checked ebay and any other dash trim places, and result isnot good.
They do have tons of timr pieces for up to 94, but 95 is different. I thought 97 discovery trim will fit but NO.
I might have to take it out and re-finish myself.
Old 01-30-2005, 09:23 AM   #10 (permalink)
Default Try exoticwoddash.com
They have great wood kits at very good prices. Find them at:
www.exoticwooddash.com
mafpolo is offline   Reply With Quote
Old 01-30-2005, 09:51 AM   #11 (permalink)
You could strip it like any other piece of wood and refinish. That piece of wood is fairly thick.
RobertGraves is offline   Reply With Quote
Old 02-04-2005, 09:31 PM   #12 (permalink)
Default 92 classic
What is the technique for removing the old center console wood?? Pry off window switches then pry off wood??
Irvin is offline   Reply With Quote
Old 02-05-2005, 07:24 AM   #13 (permalink)
yo mama
Jonesy's Avatar
Be vewy vewy careful! It can come off easy if you take your time - do not pry too hard.
The wood is appox. 1/4" thick, using a rotary or belt sander (quicker but rougher) I sanded all the veneer off then restained as close to original as possible and reaplied a new coating (3 actually) of marine grade spar varnish. The result is actually awesome. The only problem now is that it is a diff color than the rest of the wood. Oh well more work!
Jonesy is offline   Reply With Quote
Old 02-07-2005, 02:29 AM   #14 (permalink)
BrettinSanAntonio's Avatar
I've seen two on eBay in the past week. You might check there.
BrettinSanAntonio is offline   Reply With Quote
Old 02-07-2005, 09:45 AM   #15 (permalink)
Default They are not the same
I checked ebay and they are either for pre 95 or P38 shifter trim.
95 had a different style shifter wood trim.
