Old 04-20-2006, 08:07 PM   #1 (permalink)
daway's Avatar
Default change fuel filter
does any1 have any good tips on change the fuel filter and conecting hoses. i have a '93 lwb. i read that alittle gas will come out while changing?
Old 04-20-2006, 08:44 PM   #2 (permalink)
M. Hensley
mensley's Avatar
I just got my new fuel filter in the mail today with lots of other goodies, someone needs to guide us (before I even take a look at the manual)
...daway, maybe because there are two of us you will get a quicker response(...?)
mensley is offline   Reply With Quote
Old 04-20-2006, 09:04 PM   #3 (permalink)
RageRover's Avatar
Hehe, well, yes a little gas will come out of the hoses where you remove the filter. Have a rag handy to catch the gas, and not catch it in your face. Believe me, gas burns like a bitch in the eyes.
This reminds me, I have to replace mine pretty soon too. LOL
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 04-21-2006, 07:41 AM   #4 (permalink)
daway's Avatar
Smile
i have a tech work manuel '90-'94 and it does not explain how to get to the fuel filter? i think u go through the right cargo side (cd changer) what they wrote. at altantic british they have a fuel filter kit for $29.95 (good deal)
http://www.roverparts.com/Parts/8989.cfm
Old 04-21-2006, 09:01 AM   #5 (permalink)
I called the local auto parts store yesterday and they had a FRAM fuel filter for $10.
I'm not convinced on buying FRAM though.
c93werdna is offline   Reply With Quote
Old 04-21-2006, 07:37 PM   #6 (permalink)
Landy-Andy's Avatar
Default RRC Fuel filter......
Hi Guys,
The easiest way I have found is,
-Remove the rear wheel
-Clamp a vise-clamp on the rubber hose each side of the filter
-Undo the nuts each side of the filter (have a bunch of rags to catch the small amount of fuel that leaks out).
-Undo the clamp bracket that holds the body of the filter.
-Install the new filter
-Reconnect the hoses.
-Run the engine for a few minutes.
-Check for leaks.
-Re-install the wheel.
I always use a $8 Fram fuel filter & have never had any problems....
change-fuel-filter-rrc-fuel-filter-fram.jpg  change-fuel-filter-rrc-fuel-filter.jpg  change-fuel-filter-rrc-fuel-filter-removed.jpg
Landy-Andy is offline   Reply With Quote
Old 04-21-2006, 10:21 PM   #7 (permalink)
Doesnt the EFI fuse need to be pulled out before changing?
Old 04-22-2006, 02:37 PM   #8 (permalink)
daway's Avatar
thanks alot for the info and the pic's
Old 04-23-2006, 12:12 AM   #9 (permalink)
rovering??
1st rover's Avatar
to my knowledge, NO it does not need to be pulled out
-Nikunj
1993 Range Rover Classic LWB
1995 VW JETTA
1st rover is offline   Reply With Quote
Old 04-23-2006, 12:13 AM   #10 (permalink)
rovering??
1st rover's Avatar
Originally Posted by Landy-Andy
Hi Guys,
-Check for leaks.
this is exactly what i do and what the tech at the shop does
-Nikunj
1995 VW JETTA
Old 04-23-2006, 01:32 PM   #11 (permalink)
RageRover's Avatar
I just get the FRAM stuff, cause it's cheap, and I have never had a problem with it, never, used their filters for a long time now, and not a problem.
In any application, replacing the filters for oil, air, and fuel, should help with the MPG situation a little, not dramatically, but helps. I think everyone knows that.
1995 RRC LWB
Old 04-23-2006, 04:29 PM   #12 (permalink)
OkieRover's Avatar
Gallery: 2
The manual says to depressurize the system. I think the first time I didn't do this. The second I did. But it was the same result.
The biggest tip I have is....
Wash the wheel well BEFORE removing. The first time you bang the wrench and get that dust in your eyes you'll wish you heeded my warning.
I punch my clown daily.
