Links
Old 05-09-2008, 05:37 PM   #1 (permalink)
Default changed front pads now strange pedal feel
94 classic LWB. had break pad dummy light on and squeaky brakes so ordered new pads and when I went to change old pads the old ones had plenty of meat left but rotors were pretty glazed. changed pads anyway and tried to scuff off glaze. dummy light stayed on anyway with new pads but worked fine. only issue now is when i press pedal maybe one out of five times the pedal will jerk a little as they grab. hard to explain feel but seems a little firm to press then goes in maybe a inch and grabs firmly. kind of rigid. anyone with any help it would be greatly appreciated.
hawaiirover is offline   Reply With Quote
Old 05-09-2008, 05:41 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
should have had the rotors turned or replaced them then you probably wouldn't have the grabby brake issue
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-09-2008, 05:45 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
It will be that you attempted to clean the glaze off the discs. It would appear that you cleaned it off better in some sections than others.
To get the glaze you are probably heating up the brakes a little much through over use. I use to have this problem due to the amount of off-road miles. Changed the pads to something a little coarser and do not have the problem anymore.
Old 05-09-2008, 07:34 PM   #4 (permalink)
didn't have time to replace rotors when took apart because didn't know they were bad and have none available locally here in Hawaii so trying to scuff was only option until can get some. doesn't really feel like its not grabbing the rotors more seems like the pedal isn't smooth when you press. kind of steps a notch when you press. kind of a jump in the pedal. sorry only way i can really try to explain. possibly the caliper hanging up? very strange feel.
Old 05-10-2008, 09:38 AM   #5 (permalink)
ohiorover's Avatar
Default ??
Can you turn rover rotors? Someone had posted that the metal was two soft to have turned, urban myth ? I need to turn mine, but don't want to pull them and then sit while waiting for the UPS man for the replacements. Advice.
ohiorover is offline   Reply With Quote
Old 05-10-2008, 01:37 PM   #6 (permalink)
94 Defender 90
cellulararrest's Avatar
New rotors aren't very expensive. Why not just replace?
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 05-10-2008, 04:08 PM   #7 (permalink)
I'm willing to deliver four rotors - will install and bleed the brakes as well. I only require airfare for two and a place to stay for a week!
Rob
rturbett is offline   Reply With Quote
Front Brake Pads for D1 LR Max Land Rover Parts and Accessories 0 06-05-2007 05:18 PM
[ALL] Detailing FAQ's + Technique Disco Tech & DIY 0 01-08-2007 03:31 AM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
What is a good front brake pads? AdrianL Range Rover Classic 4 05-06-2005 03:09 PM
