Old 12-10-2007, 04:21 PM   #1 (permalink)
Question Changing front shocks.
Happy holidays to all.
I have a 1989 RRC and would like to change my shocks. Do I have to remove the front springs or can I remove the turret that secures the top of the front shock. Also any suggestions on removing the bottom nut on the shock, it looks pretty tight in there.
Thanks in advance..
Triple R is offline   Reply With Quote
Old 12-10-2007, 04:50 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
You can remove the shock without pulling the spring by unbolting the tower but be careful not to snap off the studs.
If the bottom bolt is frozen a saws all with a high speed metal blade works perfectly
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 12-10-2007, 07:18 PM   #3 (permalink)
Underwater hockey is no dumber than any other sport
Roverdude's Avatar
Yup, just remove the shock tower. You can get to the bottom nut w/ a 3/4" racheting wrench, but it's still a pita. You need to find a good way to hold the shock body through the spring and in most cases, the shock will be oily. Cutting it off is prolly easiest.
"Guinnevere" '91 RR
'08 LR2 SE
'05 MINI Cooper Convertible
Roverdude is offline   Reply With Quote
Old 12-11-2007, 06:22 PM   #4 (permalink)
Thanks guys, I will saturate the tower bolts and lower nut with PB blaster at least a week in advance.
Old 12-11-2007, 08:42 PM   #5 (permalink)
Rebuilding Rover
ArmyRover's Avatar
good choice and good luck
90 RRC Parts truck
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 12:51 PM
front d2 shocks drum655 Discovery Series II 4 02-26-2006 09:05 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Front Shock Replacement Figman Discovery Series II 3 07-07-2005 04:16 PM
