I have a check engine light on my dash. Code reader under the passengers seat of my 95RRC shows nothing. Just had the rear seal replaced on the 4.2 and some dash work done (new blower switch) so the console was removed. Is there a wire cut or a connector not connected under the console or under the pass seat or something? What powers the display - just the ECU? no fuse? Would liek to know what my code is!
It is definately the check enginer YELLOW light on the dash, I know where this baby is! Been on a few times since I had the vehicle. I guess simple things to check are the connections. A code typically pops with o2 sensors (so I will check those connections since they had to be disconnected to get the y pipe down and the gearbox out for the main seal), etc. Just not sure why the LED display is not lighting up.....
![]() Join Date: Dec 2005
Might be a MAF sensor issue, not sure. How are the connections on the LED Display? Might be a break in a connection somewhere.
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
It may not be a code at all, for one part it could've/would've put the fuel system into open loop, and not allow the engine to run right. But.....
It may have been a wire that came disconnected, look at a wiring diagram that shows every wire that goes to the computer and trace them to the components for a break or loose connection. It would be a long task, but at least you'll know. It could be the computer itself, but I have no idea how to test these Land Rover pre OBD II computers.
| Thread Tools | |
| Display Modes | |
