Old 09-06-2004, 11:42 AM   #1 (permalink)
Default Classic Range Rover Air Con.
Hi
I have a classic range rover and have kenlowe fans that sit in front of the radiator and directly behind the grille I have purhcased an air con system and found that the air con radiator should sit where the fans go- the fans are the new weird looking ones with the 'tail'. would it be ok to make some brackets and put the air con radiator behind the engine radiator and if front of the engine?
any other suggestions?
many thanks
Simon
simon285 is offline   Reply With Quote
Old 09-07-2004, 08:50 AM   #2 (permalink)
loadsalandys's Avatar
I must admit that I would be more inclined to fit the a/c condenser where it is supposed to be as all the brackets are there already to bolt on to, and put the kenlowes on the engine side of the radiator...or just put the viscous coupled fan back on the engine!
'68 Series 2B 110" FC Overland (Not a 101)
'72 Lightweight S3. V8 4.2 efi
'86 Range Rover 6x4 TACR2 Ex RAF
'94 Range Rover LSE Autobiography
'92 Range Rover SE (Written off by wife, grr)
'93 Mitsubishi Delica 4x4
'74 MGB GT V8
'00 PT Cruiser
loadsalandys is offline   Reply With Quote
Old 09-07-2004, 03:07 PM   #3 (permalink)
Hi
thanks for input I think thats what ive decided to do, kenwlowe says i need an adaptor to turn them to sucker rather than blower and then ill put the condenser where it should be and the fans behind the radiator
many thanks for the input
Simon
