Links
Old 08-12-2006, 06:33 PM   #1 (permalink)
bargecapt
Default clearing codes on 95 classic, which plug????
got a code 48 (stepper motor, which was replaced) and want to clear the code. book says disconnect serial link mating plug for 5 seconds with ignition on.
did this to about a dozen plugs, and still have code. what exactly does this plug look like, color, and where is it located?
thanks, barge capt
bargecapt is offline   Reply With Quote
Old 08-30-2006, 02:55 PM   #2 (permalink)
glenncof's Avatar
I assume you have ECM codes, not ABS. Disconnect battery for a 10 seconds or so.
ABS is connector under driver seat, see manual (Hayes) for detail. Battery disconnect will not clear ABS. Put in jumper, turn on ignition, remove jumper with ingition on.
This was on 1991 RR.
glenncof is offline   Reply With Quote
Old 08-30-2006, 04:01 PM   #3 (permalink)
LANDY96's Avatar
thanks, barge capt
I had the exact same code on my 93. I cleaned the stepper motor, then I re-installed. When I did that though, I disconnected the battery. So when I reconnected the battery, the check engine light was not illuminated. (never checked to see if the code appeared )
What were your symptoms, or did you just change it b/c of the code?
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
