Rocky Mountain High
![]() Join Date: Sep 2005
I have a weird clunk noise coming from the rear axle ( I believe), but not a normal pattern. The noise is random. The noise happens most when takeing off from a stop (either in drive or reverse). But i can't duplicate when i want. I have looked many times and nothing seems to be wrong.... The closest i can figure is the stabilizer (the leveler in the center of the rear axle).. Any ideas?
Can you tell if the Boge leveller is sagging at all? Take a look at the differential. Could you remove it or would removal be blocked by the lower arm of the leveller? I'm getting ready to remove mine because it is sagging and I get a similar clunking sound sporadically under acceleration, deceleration, and cornering. I don't expect any problem because I'm using heavy duty springs in the rear and they should keep the back up nicely. Yours could need only new ball joints or it could require a new Boge. It's not uncommon on vehicles this old.
Rocky Mountain High
It didn't seem to be sagging, that is the first thing i though of. I saw a picture a few months ago of a guy who put a OME spring in there and it got rid of his problem... Have you heard of that?
rovering??
i get it some times .. generally when i shift from park to revrse od drive...
its a fretty big clunk ... and from what i know it is the tranny doing that ...
-Nikunj 1993 Range Rover Classic LWB 1995 VW JETTA
You can get rid of the Boge Leveller as long as you are using heavy duty springs. From what I have been told, the Boge system does little or nothing when using springs that give you a bit of lift (2") anyway. Using the Land Rover HD or OME HD springs will work to properly support the rear of your Rover and you can be rid of another source of problems in older trucks. Afterall, look at the rear suspension on the first series Discovery. The rear suspension does fine without the complexity of the Boge system.
#12 (permalink) |
Forward!
Funrover what type of springs are you running? I used to offroad with a guy that had 90 RRC lifted the whole nine yards, and he took his Boge self leveler out. Used it as his daily driver, and he drove like a nut! Never had any issues with it. As long as you have stiffer spring in the rear there should be no issues.
#13 (permalink) |
Forward!
Have you checked the ball joints on the self leveler yet? That might be your problem, they have a tendency to wear. Oh yeah I forgot to mention about that guy that removed his Boge leveler. According to him, removing it allowed more rear axle flex also! Don't know if there is any truth to that as my 89 still had it, but that is what he said.
#14 (permalink) | |
Rocky Mountain High
#15 (permalink) | |
Forward!
If it starts to sag throw some stiffer springs under it. Hell if I lived closer I would help you with the job. |
