Old 02-23-2007, 06:31 PM   #1 (permalink)
Default Code 14
I found that it it the coolant "thermistor"? Is that a thermostat? I don't have good heat, and the check engine light is on.
1990 RRC colorado silver, tan leather all stock
Gotroxblazer is offline   Reply With Quote
Old 02-23-2007, 07:50 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
http://www.okierover.com/tempsensors.htm
This might help ya.
I punch my clown daily.
Old 02-24-2007, 06:53 AM   #3 (permalink)
I'm hoping that my problem is as cheap of a fix as yours. Did you have to replace the sensor for the fans? *I mean, was that part of the problem, or was that a seperate problem? Great site, it has been bookmarked!
Old 02-25-2007, 04:53 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
I think I did. It didn't change my fan situation. Because they weren't broke. They spin cause my fan on the water pump runs all the time. When the AC fans come on to help with cooling you can really hear them.
It turned out to be a different problem.
So check the fuel rail sensor and replace it if necessary.
Old 02-25-2007, 04:54 PM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
Is your thermostat working correctly?
Have you lost some coolant fluid?
Old 02-25-2007, 05:24 PM   #6 (permalink)
94 Defender 90
cellulararrest's Avatar
http://www.d-90.com/forum/showthread.php?t=11003
Don't know if it'll help you, but it's some more info.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 03-26-2007, 09:54 AM   #7 (permalink)
http://www.roversnorth.com/store/pc-...olant-efi.aspx
Is this the "coolant thermistor"?
Old 03-26-2007, 10:45 AM   #8 (permalink)
OkieRover's Avatar
Gallery: 2
That's the one.
Old 03-26-2007, 10:51 AM   #9 (permalink)
AB has it for much cheaper.
http://www.roverparts.com/Parts/PRC7918.cfm
Kevin
88 RRC "Audrey"
Old 03-26-2007, 02:15 PM   #10 (permalink)
Cool, I tried cleaning the contacts and plug back in, light came back on. Is this the only part associated w/ the code 14?
Old 03-27-2007, 06:24 AM   #11 (permalink)
You can check the sensor with your Ohm meter. There's a chart in the fuel injection section of the shop manual. How's the temperature? Is it running cold? You might have a thermostat stuck open which could also explain your lack of heat. Or you may have air trapped in the system. Do you hear gurgling sound from the heater?
Kevin
88 RRC "Audrey"
Old 03-27-2007, 12:56 PM   #12 (permalink)
No gurgling sound. I was planning on flushing the cooling system and replacing the thermostat. The code 14 wouldnt' be related to the thermostat stuck open, would it?
