Old 04-06-2007, 12:20 PM   #1 (permalink)
campbell's Avatar
Default Coil conversion
Today was the day that the pump, pumped no more. I ordered coils from Rovers North> I told Mike that I use my truck as a daily driver,and do a limited amount of off road, but some all the same. He sold me the O.E. coils and told me that the ride height would be in the middle of standard and off road. I really wanted to have more lift, but he explained that the ride would be considerably stiffer. Do you think that I will be dissapointed with the results?
campbell is offline   Reply With Quote
Old 04-06-2007, 03:07 PM   #2 (permalink)
Desmo Rover's Avatar
I have the same springs on a '95 RRC and I like them. The RN "kit" is basically Disco rear spings, with Defender fronts. My truck is mostly an on-road beast, but I have put BIG BLUE springs(both std and 3" lift) on other RR's and they where stiffer. And the ride height of the STD Big Blue and the OE coils is very very close.
I would recommend getting better shocks if you haven't already done so. I've used many different types(blistein, OME, etc), but I'll tell you for the $ you can't beat Pro-Comp Es9000. I think they were like $165(shipped) for all 4from SUMMIT Racing. I've kicked the snot out of these shocks and never had a problem(on or off road). If you need the part numbers, PM me.
I think you will be in good shape with the OE coils.
Desmo Rover is offline   Reply With Quote
Old 04-06-2007, 03:07 PM   #3 (permalink)
RageRover's Avatar
Honestly no I don't think so. There is always that heated debate on spring rate and brand of shocks you get, but one thing I think is, that because they are not HD lift springs (ie. Rovertym 2" lift springs), you're ride will be pretty superb. What kinda shocks you running?
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 04-07-2007, 05:50 AM   #4 (permalink)
campbell's Avatar
Thanks for the reassurance guys. As far as I know the truck still has O.E. shocks. When I asked Rovers North, he said that if they arent leaking dont replace them. Being that a sales guy was actually telling me not to buy, I took stock in his advice, but now I am thinking of ordering new, and having it done while the truck is torn down for the conversion. I guess it just makes sense to take advantage of the situation, and get r done> I am going to the summitt site now........
Old 04-07-2007, 07:18 AM   #5 (permalink)
Ben
TN-LR3's Avatar
I have OME HD shocks and springs on my 92' that i'm about to sell to go taller, they ride better than stock so don't listen to roversnorth. I mean ya they sell some nice stuff but they did copy badger coachworks soft top and claim it to be theirs
1997 D-90 #1345- Bunch of stuff
1992 RRC LSE- for sale/ maybe crawler project
2002 Dodge ram 2500CTD- dd/tow rig
TN-LR3 is offline   Reply With Quote
Old 04-07-2007, 11:20 AM   #6 (permalink)
Just my 2 cents, but there is a HUGE difference in OE Hydro Woodhead shocks compared to just about anything nitro gas(bilstein, pro comp, etc). The ride of a RRC improves a ton with a gas shock! The lumbering, waste of energy side-to-side motion is almost gone. But, you still retain a smooth ride(it is a ROVER after all...LOL). I know the "feeling" of a shock upgrade is very subjective, but IMHO swapping shocks is one of the best things you can do to a ROVER.
Are you having a shop do the conversion? I'd love to know what someone would charge to do this job. I've done so many, maybe I'm in the wrong business.
Old 04-07-2007, 11:27 AM   #7 (permalink)
campbell's Avatar
The parts I ordered myself, coils including a steering damper+shipping 500 bucks, and the shops labor will be about 500 bucks. That estimate included replacment of the shocks. So I get the feeling I neede to order a round of gas shocks.
Old 04-07-2007, 11:42 AM   #8 (permalink)
campbell's Avatar
This is from autoparts warehouse.com.
I dont think they are gas filled. What do you think?
L4000-54401
Product: Shock Absorber Rear (OES)
Vehicle: 1995 Rover Range Rover 3.9
Notes: Rover 1995
Shipping: This item is shipped Ground, 2nd Day, and Overnight.
Update
Remove $55.95 $111.90
L4000-51032
Product: Sachs Shock Absorber Front
Notes: Rover 1995 Sachs
Update
Remove $74.95 $149.90
Old 04-07-2007, 12:07 PM   #9 (permalink)
Personally, go with a gas shock. I found the Pro-comp es9000 part numbers:
Front: 921560
Rear: 921573
Boots: ?
I order these from Summit Racing(about $165 shipped with boots), but just a heads-up if you go this route call Pro-Comp(800.776.0767) and order the larger bushing kit: P-1029 (you need 6). If I remember they were like $10 (for 6) and they fit the cups MUCH better. If you are thinking of getting these from RoversNorth, ask them if the shocks come with the larger bushings. I know someone who bought them from RN and the shocks came with the wrong size.
It's too bad that you can't do this job yourself. $500 is OK, but man this job is as dumb as dirt to do(especially the shocks). But if it's a lack of tools, etc. your stuck.
Good Luck!
Old 04-07-2007, 12:31 PM   #10 (permalink)
Thor's Avatar
We had 3 Pro Comp shocks range from major leak to explode... not bad for only 8 being there to begin with. I think the issue was the welds and the metal thickness in the body of the shock.
Not the first time I've heard this.
I've always loved Bilstein. 7100's on the rig now.
If I were you I'd call Bill at Great Basin Rovers and discuss your suspension needs.
Todd
Carpe Rangius Roverum
Old 04-07-2007, 12:35 PM   #11 (permalink)
campbell's Avatar
I just found that the pro comps are out of stock. Thor-do you happen to have contact info for great bison?
Also- you have a 95 RRC?
Thanks much guys for the great info.
Old 04-11-2007, 04:35 PM   #12 (permalink)
campbell's Avatar
I just got my truck back from the shop that did my coil spring conversion. I am very satisfied! It drives sooo nice now, and the lift is just right-not too much> Thanks to all for all the great advice. Also, the shop charged me 360 bucks to do the conversion, steering damper and removing the front air dam. Very reasonable in my opinion.
Cheers!
Old 04-11-2007, 07:35 PM   #13 (permalink)
Thor's Avatar
http://www.greatbasinrovers.com/aboutset.html
Call for best results.
I had a 1995 RRC swb (OME MD, Bilstein for EAS shocks, 235/85r16 MT/R) then sold after I bought a larger 1992 RR1 that does everything well.
Sorry for the late reply.
Todd
