Old 12-04-2007, 06:42 PM   #1 (permalink)
Default Coil Springs color codes
Are the springs color coded? ?If so does any one what color is what.
skippermccoy is offline   Reply With Quote
Old 12-04-2007, 07:38 PM   #2 (permalink)
WWTSD? (what would Tony Soprano do?)
stevo-II's Avatar
here you go man, check about 1/2 down the page....all you ever wanted to know, and then some
land rover spring specifications
2001 D2 -The Stevo-II
1992 RRC-The Stevo-I
stevo-II is offline   Reply With Quote
Old 12-05-2007, 04:37 AM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
This one has a more complete list
http://www.4x4store-exeter.co.uk/cat...ry/SPRINGS.HTM
The colour is simply a brush stroke running from top to bottom on one spot of the spring.
Old 12-05-2007, 08:11 AM   #4 (permalink)
Thanks for the info. Mine does not make any sense. I have blue on the drivers front,pink on both rears and white on pass front. It sits higher then the neighbors rrc. It does not have any spring risers or spacer in either.
MY non flexing truck fivespddisco Accessories 126 10-24-2007 04:45 PM
Land Rover Coil Springs 88gspd Land Rover Parts and Accessories 4 09-26-2006 01:27 PM
front coil springs kennyday Discovery Series I 8 06-27-2006 06:36 PM
Disco coil springs Jaco Discovery Series I 11 08-02-2005 08:44 AM
coil springs and leaf springs indrika Off Road 2 05-21-2005 09:22 PM
