on my 95 LWB, Ignition to on position, power comes up on cigarette lighter and when I start the car, the power cuts off and re-powers again. Is there a way I can re-wire so it has continuous power even if the ignition is off?
Sure.
Run a wire to the battery. Be sure to put an inline fuse on it. Or you could look for 12v live under the dash. I think personally it would be easier to run a wire to the battery. But whatever make sure you fuse it. |
![]() Join Date: Dec 2005
Ditto on that, I might do the same, not that my outlet is not working, but use it so that it doesn't require me to insert and turn the key.
Just be careful as will I, that what ever you plug in there won't drain your battery if you use anything without the engine running. ![]()
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
that soulds like a good idea! what is the easiest way to change the bulb on the front lighter ('93 LWB)? can i pull it out of the dash or do i have to take off the "shell" next to the radio?
