» Sponsors
» Sponsors
Old 07-01-2009, 11:45 AM   #1 (permalink)
Sign Guy's Avatar
Default Coolant cap defective or head gaskets?
Blew the temp sensor out on the upper hose this afternoon. I rebuilt the engine about 6K miles ago and have had to add about a pint and a half of coolant in that time which was due to small leaks here and there. There is no bubbling or gurgling and the oil looks good with a stable level. I had been somewhat concerned that the pressure was too high since the upper hose seemed to be a bit firm, not hard but firm. I zip tied the sensor back in place refilled the reservoir and put the cap on not quite snug and drove home without issue. Bad cap or should I go ahead and plan to do another head gasket job. Oh yeah, it didn't even come close to over heating. I heard it blow and coasted to a stop.
Bill
93 LWB Sable Edition 165+k miles
ArmyRover- "it's actually more of self inflicted torture chamber with doors and tires"- with this, I can relate!
Sign Guy is offline   Reply With Quote
Old 08-03-2009, 10:19 AM   #2 (permalink)
Sign Guy's Avatar
Is it normal for the radiator hose to get harder as the revs rise?
Bill
Old 08-03-2009, 01:00 PM   #3 (permalink)
1993 RRC-ville
my guess is you had an air pocket or bubble and didn't burp it out during refill. probably a small crack in the "T" somewhere as well. I pieced together a threaded solid T fitting from advanced auto and cut/inserted it into a cheaper straight pipe -- it works better and no leaks at a rubber junction. what a poor factory design...
use WATER WETTER (autozone). read directions closely...about $7.99
Did you remove the air burping plastic plug on the passenger side of the engine when refilling?
1993 SWB RRC 125K, mantek snorkel, 2" lift
1993 LWB RRC 62K 245/75 MT, mint
cold_surfer is offline   Reply With Quote
Old 08-03-2009, 03:48 PM   #4 (permalink)
Sign Guy's Avatar
I've got bubbles across the top of the radiator. It's head gaskets.
Bill
97 Disco 1 Head Gaskets LRDMICHELE Discovery Series I 15 03-18-2009 11:17 AM
Just replaced head gaskets, and now smoke from exhaust 68dodge500 Discovery Series I 1 12-20-2008 09:49 AM
just did head gaskets and still loosing coolant kkrover Range Rover Classic 4 01-29-2007 09:09 PM
Leaky Head Gaskets 95' LWB 99,000 miles NJRover Range Rover Classic 5 11-18-2006 05:09 AM
Head gaskets on a 4.2L deadboy1977 Range Rover Classic 17 03-20-2006 12:38 PM
SEO by vBSEO 3.3.2
