Old 07-10-2006, 08:03 AM   #1 (permalink)
Default Coolant hoses to plenum?
Just want to double check that I put them on in the right order. My notes and photos were not completely helpful. So there are two hose attached to the plenum. Does the small one from the intake manifold go to the left and the one from the radiator go to the right?????? Or do I have them backwards?
Here's a pic just in case of where they attach to the plenum.
Kevin
88 RRC "Audrey"
Old 07-10-2006, 10:46 AM   #2 (permalink)
Does not matter, the coolant flow just warms the air going into the intake
tlry00 is offline   Reply With Quote
Old 07-10-2006, 10:59 AM   #3 (permalink)
Thanks!
You are probably right that is does not matter, but I just talked with Rovers North who said I had them backwards. The little one to the intake should be on the right if looking at the plenum from the front of the Rover.
Thanks again.
Kevin
88 RRC "Audrey"
Old 07-10-2006, 11:50 AM   #4 (permalink)
RageRover's Avatar
Here's a question. Can you just remove that entire hose completely, block of the connection on the raditor and intake port?
If it just warms the air, removing it might have a performance gain?
Just curious, but I think there might be a negative effect if one were to leave that hose off.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-14-2006, 11:38 AM   #5 (permalink)
AFIROVER
afirover's Avatar
you can remove it if not needed its the plunim deicer for the "artic" cold ass mornings if you live in fl you will not need it
mine is off and i live in IN had no issues
good luck
afirover is offline   Reply With Quote
