Mine hangs down too much, and I think I will end up ripping it off! Will it affect back pressure if I do this. I have supplied a picture so you can see what I mean! Thanks!
Eric The Red 93 Range Rover Classic ![]() We will never "arrive" so the goal is to keep moving forward on our journey so we can periodically declare, "I am not what I want to be, but I am not what I used to be!" 96 DISCO SE7 5-SPEED SOLD ![]() ....okay couldn't live without a disco!96 DISCO SD 5-SPEED -ARB Bumper -OME 2" Lift -2" spacers -Safari snorkel -15" steelies
can u just hook it up on the muffler bracket or just tie it up some how? in the pic there is that steel tie up w/ holes (can't think of the name). if u cut it off it might get loud and do u have any state laws about mufflers?
1993 RRC, county LWB "bertha" 1991 RRC (dad's), parting out (email me or check out the link below) myroverworld Last edited by daway : 10-06-2006 at 07:42 PM. |
who that is?™
mine is cut off right after that last hanger. It felt faster 0-60, but that could be just because of the sound.
1995 Disco on 33's 1988 Range Rover- trimmed fenders, big rack, HIDs,... 2000 Turbocharged Explorer 5.0 AWD....'tis fast 2005 Ford F150 4x4... company vehicle |
The MoFab Man
If your talking about the rear mufler, YEs ! Its not going to hurt anything and it might sound a little beefier but not loud at all. you can re use you turndown tip to keep the clean look if you can tack it on.
* * http://www.MoFab.org * * * Are you gonna pass that ?? * 99' D1 55' S1 86" RHD SW 00' RR 4.6 HSE My Favorites: http://www.texasrovers.com/ http://pikespeakrovers.com/ http://oeminstock.com/ http://greatbasinrovers.com/ http://MyRover.net/ Yep, thats my truck in the avatar.... |
my name is Todd, and I'm a rovaholic
I ripped my off up in the hills two years ago and have yet to do anything about it. Doesn't feel faster, hardly louder too. Now...the cracked exhaust header that also happened when I ripped the muffler off...that's a different story. I should probably get that fixed...
I can send you pictures if you like...it's funny seeing yours and seeing what I've been missing for a few years.
'05 Scion xB '91 Mercedes 300SE '95 Range Rover Classic LWB '60 Ford F-250 '78 Ranger20 Sailboat '71 Melges M-20 Scow Sailboat TRY? There is no TRY. There is DO and DO NOT. -yoda |
#7 (permalink) | |
Thanks for the input people, I will just cut it off!![]()
![]() Join Date: Dec 2005
Believe it or not, there is such a device called an Exhaust Backpressure guage.
SOunds funny, but I have used these things before.If you have no backpressure, it can create a sight hesitation, unless you're timing is advanced a bit. That's why when I put the glasspack on my exhaust, in place of the huge muffler in the center, and hacked the rear resonator, like the one shown in the above pic, my timing needed some adjusting. I am willing to bet that when I did the exhaust on my truck, the back pressure went from like 5 psi, to like 2-3 psi. No psi, is bad, not good for a daily driver. Too much, you have clogged cats, and/or muffler(s). Either way, I did the exhaust, just messin' with sound and backpressure, and all-in-all, my truck has better running performance, and I have tested my truck at college with a 5 gas analyzer, and my truck passed emissions. ![]()
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
#9 (permalink) |
who that is?™
the rear muffler is was the only muffler on my '88, so now I have no muffler
#12 (permalink) | |
#13 (permalink) |
Ian Matthews
Be careful when putting it out the side so that it does not stick out past the quarter panel. Otherwise you are likely to ram it up through the quarter panel if going over steps off-road
#14 (permalink) |
I drink too much
i positioned it as close as i could to the inside of the wheel well. That tire in full compression wont touch the exhuast but it gets close and its so tucked up in there i would have to drop that rear tire off a 90 vertical with zero forward velocity in order to bump it. Its a very out of the way spot, much better than the factory set up.
#15 (permalink) |
Rocky Mountain High
![]() Join Date: Sep 2005
CUT IT OFF!!!! You don't need it...... It wil only catch while wheeling.... Ask discodude19 what happened to his....... I have not had mine on in roughly 3.5 years.... No problems here!!!
