was putting my spindles back into my axle housing today...
Driver side CV has a lot of play, that feels like a hub with a bad bearing would.. thats why it was leaking out the seal i suppose. EDIT: Found out I'm an idiot, and I took it apart again and realized the CV mount on the top, that holds the brake line mount, was loose because I have taken the brake mount off and just left that a couple threads in.. so the CV is fine. This brought me to another question. I was planning on replacing the rear axle that was rusted out on mine, with one from either my 87 or 88 rover.. I just noticed my front axle is suffix B, so the 87/88 are suffix A. QUESTION: Can I put an entire suffix A axle and all it's parts on a truck that had suffix B, and has front suffix B? I'm assuming there is a suffix a and b for the rear since there was for the front. Thanks for any help.
Devon Yablonski 1989 Range Rover Classic - Running and Muddy 1988 Range Rover Classic - Parts http://ads.auctionads.com/pagead/lin...assZyieldsign2 Last edited by yieldsign2 : 12-21-2007 at 11:30 AM. |
I've got a set of '89 RRC hubs and CV's if you need them, super cheap.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
Turns out my CV seems fine, besides needing a new seal now..
Original post edited with new questions, thanks!
Devon Yablonski 1989 Range Rover Classic - Running and Muddy 1988 Range Rover Classic - Parts http://ads.auctionads.com/pagead/lin...assZyieldsign2 |
Bump.. No one has ever tried to put a A suffix axle on a B suffix axled car?
| Thread Tools | |
| Display Modes | |
| Respray questions | CanuckIIA | Series Land Rovers | 11 | 08-06-2007 03:13 AM |
| CV Joint replacement info Please! | Denver Dan | Range Rover Classic | 10 | 03-04-2007 08:30 PM |
| [D2] CV Joint Trail Fix | rmuller | Tech & DIY | 0 | 01-03-2007 02:53 PM |
| DII CV Joint Field Repair | SCSL | Off Road | 1 | 05-30-2006 09:50 PM |
| U-joint | roverX | Discovery Series I | 2 | 03-22-2006 03:54 PM |
