Just out rovin about
hey all rover dead...typical no start i need some ideas...as it cold and raining out so im trying to not get every jacket i own soaking wet while workin on this.... ok heres what we have 91 gde aka a 90....been haveing cold hard start issues.. nothing major just cranks a little longer then fires idles high then settles down around 800 or soo.... with a very strong fuel smell out the exhaust even after warm up.. i went out yesterday the first day that it has been above 35 40f out in the am and started the truck fired up the sputtered...and died and no start every since.... checked plugs were very worn and gas soaked bad...checked the leads all good there minimal resistance there and look some what new...checked cap heavly corroded polls inside cheap tin cap not a good brass one... checked steper valve and cleaned it wassnt bad at all looks some what new.....check all vaccum line...put in new champion plugs got a sputter after long crank...pulled them out gas washed again... put in ngk plugs same thing long crank with a sputter... checked spark seams very weak to weak to be honest.... now heres the thing im thinking bad coolant temp sensor makes it run rich ...when it was super cold out no big issue becouse it needs the extra fuel to run... but now thats its not super cold out its gas washing the pistons... andhaveing a weak coil isnt helping to light off the extra gas....soo please if there are any other mechanics out here helpa brother out....cannt just keep throwing parts at this thing..... sorry for the long post i just hate it when people have a peoblem with there cars and dont give any info...thanks Don
91 G.D.E. project/daily winter driver 93 BMW 325i project/daily summer driver:SOLD: ![]() 00 BUELL cyclone custom ![]() http://www.snhlr.org/
update i replaced the coil.. put new connectors on the wires..and still no go....but now am gettin code 14 for coolant temp sensor.... any thoughts???
Don,
A faulty temp sensor will definitely cause the truck to run rich. YOu might want to swap yours with another snesor, clean the plugs and try again. If you don't have access to another sensor let me know and I can send up one to see if it will help. Cheers, Paul |
update got it running but nowhas dead miss going to recheck fireing order and seewhat it does...
alll better now!!!!! found that the ignition pickup <under the yellow cap inside of the dist> was all corroded and making intermitent connections .. pulled it all out cleaned all connections and reinstalled all better and to be honest is running the best it has since i owned it..... oh yea also pulled thecoolant temp sensorand beadblasted all the corrosion off the brass and the plug pins.....all and all im a happy camper now ...
oh yea thanks for the offer paul becouse nobody around had a sensor...lol you would have been getting a call from me
No problem. I'm glad you got it sorted out. I was talking with Kevin when I was reading your post and we both thought that the temp sensor could be causing it to run too rich. Anyway, if you ever need an oddball part like a sensor just to troubleshoot let me know and if I have what you need I can always get it to you quickly.
| Thread Tools | |
| Display Modes | |
| Famous Owners of Land Rover vehicles | Bleed Green RRC | The Lounge | 37 | 08-28-2006 01:40 PM |
| Land Rover Frequently Asked Dumb Questions (very long...but funny) | JungleRR | General Land Rover Discussion | 0 | 05-26-2006 10:37 AM |
| Land Rover: Truly 'Extraordinary' | Serg | General Land Rover Discussion | 0 | 01-31-2006 12:37 AM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 02:18 PM |
| Range Rover Sport Seems to have it all | Serg | General Land Rover Discussion | 1 | 12-05-2005 01:54 AM |
