ryans ROVER
i hava a 94 range rover lwb...my onboard diagnostic display showed 44 which is the left oxygen sensor but iv also heard that code 44 can mean that the engine is running rich...my MAF sensor is just about dead and im wondering if this would cause a code 44? or mayb i need to replace the MAF sensor and the oxygen sensors...
How's your gas mileage?
If you've noticed it's dropped off you should replace the O2 sensors anyway. So maybe if you're looking for justification.... |
![]() Join Date: Dec 2005
How bad would the two O2 sensors on a 4.2 affect the MPG's of the Rover? Cause I get about an average now of around 13 maybe 15 MPG on the freeway, and maybe something else is contributing to the thing.
My 1993 LWB went from 14.5-15.5 to 12.
So I'm gonna replace them this summer. |
#5 (permalink) | |
I'll have to look them up. They are under 150$(US) each if I remember correctly.
How do they affect the gas mileage? They control the richness of your mixture if I understand it correctly. Older sensors give the computer readings that cause it to run richer. Which is why you see a drop in mileage. OF course I could be wrong. But when I replace mine my mileage goes up. |
http://www.landroverparts.us/LandRoverSpecial.html
For Wednesday. Good news your sensor is on sale. ERR6729 I'm buying 2 as soon as I finish this post. |
Bought two just now.
Tell them Eric Stephens sent you. I won't get anything for it...but at least they'll know we talk about them. |
#9 (permalink) |
If it was me i would replace the bad sensor, not both. Nathan at Discount Rovers used to sell them for 95 bucks but I cant find his website? Did he go out of business? Anyway, when the EFI kicks a code the ECU goes into full rich mode and gas mileage goes down the drain. My stock RRC in top shape gets 16 hwy running premium fuel. Gordo
Gordo www.floridalandroverclub.com 00 P38 4.6 blinging 92 stocker RRC 73 hybrid wheeler |
#10 (permalink) |
1993 Range Rover County LWB
Nathan's new website is: http://www.discountbritishparts.com/
The new URL doesn't seem to be well-known yet - I was looking this up a few weeks ago, and it took me ages! Nathan seems to have a great reputation, especially when it comes to the oxygen sensors!
- Ian 1993 Range Rover County LWB / 1996 Rover Mini SPi / 1965 MG 1100 |
#11 (permalink) |
ryans ROVER
so i bought a new sensor and just replaced it with the old one...the check engine light is still on and the diagnotic code 44 is still showing even after i reset it...will this eventually turn off?
ryan mura 1994 range rover county lwb -BIG BLUE 3" coil spring suspension lift -Procomp ES3000 shocks -custom snorkel -glasspack exhaust system -285/75/R16 all terrain tires -old school CB radio from the 80s-cobra -speakers loud enough to set off car alarms -LR3 side air vent |
#12 (permalink) |
disconnect the battery for 10 minutes and reconnect. it should show an 02 which will clear up. If the 44 comes back then something else is the culprit but I bet you will be okay. Hopefully you know your radio code! gordo
#13 (permalink) | |
Mike |
#14 (permalink) |
ryans ROVER
i unplugged the battery and it reset the codes and everything is fine. thanks gorda
i am going to get a second oxygen sensor when i have the money. i am only highschool student having to pay for everything on my car so i dont always have enough money for parts needed
#15 (permalink) |
Ryan. I'm not sure if you've seen my page but it has a bunch of stuff you may run into owning your Classic.
Check it out. I sometimes make the false assumption every one has done "this or that" like clearing the codes by unplugging the battery. www.okierover.com Don't put off changing that other O2 sensor. Try to get it in there within a month if possible. |
