Old 06-11-2006, 10:11 PM   #1 (permalink)
RageRover's Avatar
Exclamation Did Front Brakes, Now this...
Well it took me a good day and a half to do the front brakes on my RRC, real pain in the ass. But I got it done, sorta.
Also after installing the front shaft on as well, I took it for a test run on the freeway to also break in the brakes and to see if the shaft would hold up and it did. Well, as I left the freeway on the off ramp, I heard I nasty thud. I pulled into the gas station, to fill up and looked at the shaft, and it was still solid, but then I look at my driver's side front caliper, and the bottom bolt was missing. I then realized I had lost the damn thing somewhere on the interstate. As a temporary fix, I switched the top bolt to the bottom hole, and wrenched it on there tight, and the caliper seemed to hold fine, as a matter a fact, I drove 136 miles back to college town in Lima, and I checked the caliper periodically at rest stops along the way, and it didn't move after the bolt switch.
It had to be my dumbass to either A: Not even put in that bolt at my friend's house where I did the brake job, or B: Didn't tighten that bolt all the way, and therefore wiggled its way out of the threads on the bracket.
Everything went together as planned, like as far as pulling the calipers, undoing the hub, and packing the bearings with new grease, but this one little bolt, which sounds like an expensive dealership-only part, is what made it suck in the end, but thankfully I was able to just flip the top bolt, to the bottom hole and it works fine, for now, as does my shaft.
Does anyone have a caliper bolt for the driver's side caliper for my vehicle? I really don't wanna have to go to a dealership and have to pay like $50+ for a stupid little bolt. The bolt is a 12 point headed style bolt. That makes it expensive little bugger for just being that style. If anyone could hook me up on a bolt or two, I would greatly appreciate it!!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 06-12-2006, 05:08 AM   #2 (permalink)
Pat,
I know I've said this before but....I'm pretty sure I have one kicking around here for your truck. It was 13 mm 12 point correct? Let me scrounge around and get back to you. If I have one just get me your address and I'll send it in the mail.
Remember, loctite is your friend!!! Get a tube of the blue stuff for doing the calipers.
Paul
Old 06-12-2006, 05:52 AM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
You should be able to fit a normal bolt with the same thread. Just find a bolt specialist and make sure it is a high tensile bolt. Should cost you all of a $1 or two.
Ian M
Old 06-12-2006, 06:55 AM   #4 (permalink)
Ian is right. Aside from the weird 12 point head, it's a standard bolt.
Nonetheless, I have a couple here in my hand so if you want them send me your address and I'll get them off to you.
Cheers,
Paul
paulgrant@mac.com
Old 06-12-2006, 09:43 AM   #5 (permalink)
RageRover's Avatar
Yeah, I tried this morning before going to class, at the ACO, Home Depot, and other places that sell bolts, and none of them have anything remotely close.
But yeah Paul, I will e-mail you back, I will need that 13mm, 12 point bolt. Thanks again man, you guys here are lifesavers.
1995 RRC LWB
Old 06-12-2006, 04:16 PM   #6 (permalink)
Pat,
I put a couple in the mail today.
Cheers,
Paul
Old 06-12-2006, 07:20 PM   #7 (permalink)
RageRover's Avatar
Originally Posted by Paul Grant
Pat,
Cheers,
Paul
Thanks plenty Paul!! You are a lifesaver!!
1995 RRC LWB
