Should there be any play in the distributer? There is about 1/4"to 1/2" of play in the rotor shaft. Is this correct? It is a 89 3.9 RRC. Also has anybody ever tried changeing the tuning resistor? Thanks in advance
1989 county 3.9
i believe that amount of play is correct , but there is a spring that should return the rotor when released, mine was stuck too(89 county) and i just did as the book says and put a drop or two of oil down the center of the shaft and worked it back and forth. it took quite a bit of working and re-oiling to get mine to return .but eventually it did when advance and retract on a smooth spring loaded arch. every tune up that shaft needs a drop or two of oil.
| Thread Tools | |
| Display Modes | |
| 4.2L distributor orientation | deadboy1977 | Range Rover Classic | 3 | 07-11-2007 03:53 PM |
| Odd Cases of Hesitation | RageRover | Range Rover Classic | 16 | 06-05-2007 12:04 PM |
| Range Starts! Wont Drive! | djnoble | Range Rover Classic | 12 | 11-15-2006 10:24 AM |
| 95RRCLWB 4.2L dist cap and rotor | deadboy1977 | Range Rover Classic | 3 | 10-19-2006 06:22 AM |
| Distributor | tlry00 | Range Rover Classic | 5 | 09-21-2004 07:09 AM |
