Old 03-12-2008, 10:28 PM   #1 (permalink)
RRC
Default Dist ?'s
Should there be any play in the distributer? There is about 1/4"to 1/2" of play in the rotor shaft. Is this correct? It is a 89 3.9 RRC. Also has anybody ever tried changeing the tuning resistor? Thanks in advance
RRC is offline   Reply With Quote
Old 03-13-2008, 11:48 AM   #2 (permalink)
1989 county 3.9
i believe that amount of play is correct , but there is a spring that should return the rotor when released, mine was stuck too(89 county) and i just did as the book says and put a drop or two of oil down the center of the shaft and worked it back and forth. it took quite a bit of working and re-oiling to get mine to return .but eventually it did when advance and retract on a smooth spring loaded arch. every tune up that shaft needs a drop or two of oil.
MysteryTheatre is offline   Reply With Quote
4.2L distributor orientation deadboy1977 Range Rover Classic 3 07-11-2007 03:53 PM
Odd Cases of Hesitation RageRover Range Rover Classic 16 06-05-2007 12:04 PM
Range Starts! Wont Drive! djnoble Range Rover Classic 12 11-15-2006 10:24 AM
95RRCLWB 4.2L dist cap and rotor deadboy1977 Range Rover Classic 3 10-19-2006 06:22 AM
Distributor tlry00 Range Rover Classic 5 09-21-2004 07:09 AM
