Originally Posted by Divied245
Lets start by asking, How did you lose your timing?
You should have the #1 cyl at TDC on its COMPRESSION stroke. other wise you'll put the dizzy in 180 of where it needs to be. The when you put the dizzy in, it should actually end up slightly behind the #1 plug on the cap because the timing should be set at 6 degree before TDC once you have it running and slightly before number 1 on the cap would be that 6 degrees. if you set it 10 degrees Before TDC when installing you'll be ahead a tooth on the gear.
Thanks for your reply.
Lost the timing by pulling dizzy and didn't pay attention to positions.
Being 180 is not an issue here as I've I'd firing by pulling plug 1 and feeling it with my finger popping while hand cranking.
If I understand you correctly, I should have installed the dizzy with a reading of 6btdc instead of the 10btdc I used. And then looked for the rotor to point right before the 1 on the cap. Ok, I intend to give that a try however it is running well with it currently installed at 10btdc which leads me to ask another question (probably should start a new thread to address this one.)
Does anyone know how the smog emission will result when installing a dizzy 6btdc versus a 10btdc?
