Old 04-05-2006, 12:57 PM   #1 (permalink)
Default Dot 3 brake fluid
I just bought some brake fluid for my 1992 RR Classic. As I went to put it in I saw the note on the resevior said, "Dot 4 Only"... and I have Dot 3. I have no idea what the difference is between these... Am I going to hurt my brakes by adding Dot 3 to the Dot 4 that is apparently in there?
dbrisotti is offline   Reply With Quote
Old 04-05-2006, 01:16 PM   #2 (permalink)
sven's Avatar
Use Dot4 Castrol LMA.
Old 04-05-2006, 01:31 PM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
^^^^^^^^^ x2
I punch my clown daily.
Old 04-05-2006, 02:08 PM   #4 (permalink)
Thanks!
Old 04-05-2006, 05:06 PM   #5 (permalink)
RageRover's Avatar
Is there a difference between the two brands of DOT 3 and 4? Like in viscosity?
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 04-05-2006, 05:10 PM   #6 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
i think dot 4 is synthetic and dot 3 isnt. dot 4 also has a higher temp rating
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 04-05-2006, 05:24 PM   #7 (permalink)
RageRover's Avatar
Yeah, I would imagine, since our Rovers, have four wheel disc that heat up pretty good, not to mention also the ABS, and TC that the fluid is getting pumped through.
1995 RRC LWB
