Old 05-07-2008, 06:05 AM   #1 (permalink)
Default Driver's Door Wind Noise - 95 LWB
My '95 LWB makes a godawful racket from wind noise when going over 65mph on the highway from the dirvers door...
The weatherstripping is fine, no tears, etc., door closes/opens well - body alignment is as good as any Rover. Car has never been hit or repaired other than the tailgate 10 years ago.
If I look closely, it is the top window frame/a-pillar that is moving due to the air pressure change. I can't believe my Rover is that airtight... Thoughts/ideas?
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (very ugly), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is offline   Reply With Quote
Old 05-07-2008, 09:22 AM   #2 (permalink)
Roll the window down and carefully push he window frame (with the door open) inwards toward the body a tiny amount. Try the door fit. If it still has a poor fit, try it again. Continue as needed. If you do this by small amounts each time eventually you you find a spot that reduces the the wind noise to a acceptable level without binding up the door or adjusting the the entire door out of position.
If you don't fancy bending the door and, as you say the weather strip is in good condition you could try building the weather strip thickness up with foam, this does not work as well but it should help (you can get a roll of tube foam from the hardware store). Insert the foam into the weather stripping in the area of wind noise. You may have to shave the foam down for 'perfect fit' and it is tricky to get it to lay correctly but if you keep at it the foam will help.
hope this helps.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Old 05-07-2008, 09:25 AM   #3 (permalink)
DWN4WVR's Avatar
I have the same exact problem on my 95 accident free LWB. I'll try the same thing.
Range Rover HSE (DC Metro area dinner)
Range Rover Classic LWB (Offroad lamb griller)
DWN4WVR is offline   Reply With Quote
Old 05-07-2008, 09:55 AM   #4 (permalink)
I am very comfortable bending the frame slightly - been there, done that to a big degree on my F350. I'll try that but given that the upper frame appears to bolt to the lower part of the door, I was wondering what sort of adjustment opportunities exist there. I'll tweak in the next day or two and post back - thanks!
Old 05-07-2008, 11:04 AM   #5 (permalink)
There are a few bolts that keep the window frame in place. They can be loosened and the frame can be tweaked more effectively than bending the frame with force.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 05-07-2008, 11:28 AM   #6 (permalink)
I'll fiddle with the adjustment bolts before I bend...otherwise I'd need a trip up to you to get another frame!
Old 05-08-2008, 07:54 PM   #7 (permalink)
OK - problem solved... The culprit was not the window frame adjustment or weather stripping at all. It was the screws that hold the roof panel in place! The first 3 screws in the driver's door area had backed out and disappeared into the channel somewhere. The one left was finger tight. Got new #12 x 5/8 sheetmetal screws and lockwashers, tightened 'em all down and we're good to go.
DWN4WVR - you should check yours if you have the same issue. Pop the grommets off and use a SEM style phillips driver to see if yours are still there/tight. Good luck!
Old 05-08-2008, 08:17 PM   #8 (permalink)
Ha, Ha, you just gotta love a truck that is made from all the left over spare parts from a Mechcano set!
Old 05-09-2008, 01:04 PM   #9 (permalink)
OkieRover's Avatar
Gallery: 2
The frame is not ridged on purpose.
I punch my clown daily.
Whistling noise while accelerating (rather loud) jarnism Discovery Series II 3 02-24-2008 07:59 AM
Best to Worst Drivers by Sign kellijo The Lounge 15 11-22-2006 11:31 AM
HELP !! Strange Noise stevenjamesdavies Range Rover P38, Mk III and Range Rover Sport 4 12-08-2005 02:14 AM
Squealing Noise on Startup -- Viscous Fan? Oconee Disco Discovery Series I 3 09-14-2005 08:08 AM
knocking-tapping noise on drivers side of engine... ronrover Range Rover Classic 10 01-27-2005 11:42 PM
