#16 (permalink) |
Schade
UPDATE
So, I got the Driveshaft (Thank you Paul Grant!). I crawled under her today to check out everything. The Transfer case end is clear and has all 4 screws still attached to it, just no driveshaft, but the other end, near the front axle, still has the rotating part of the driveshaft still on there (confirmed, it did "break" off. It looks like the driveshaft must have twisted until it broke off.) I took off 2 of the 4 bolts that are attaching the broken piece, and am having trouble getting the other 2 off. They are on there pretty tight. The front axle end rotates and moves the vehicle's front wheels back and forth. On a side note. Near the front axle on the passenger side, right next to the driveshaft, there is a wheel, or pulley looking device, that has two ends of cable coming out of it. both pieces of cable have torn and are hanging loose. What is this wheel, and is it something dangerous along the lines of needing immediate attention? Thanks again guys! |
#18 (permalink) | |
Ian Matthews
#20 (permalink) |
Schade
Symptoms:
Smoke/burning smell coming from transfer case. Metallic Clicking while making a left or right turn, both in drive and reverse. Any guesses? I'm going to take it to the dealer to look at it In the meantime I took the front drive shaft back out, because I don't want to damage either the front shaft, rear shaft, or transfer case any further. appreciate any help... |
#21 (permalink) |
Rebuilding Rover
the clicking noise depending on were it's coming from could be one of two things.
Bad cv's on the front axle or a blown vc unit.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#23 (permalink) |
This is a classic problem for that era rover. Scenario goes like this; front tires start chirping on tight corners, really noticeable in parking lots. Viscous coupler has failed, or failing (locking up). Viscous coupler is a wear part, just expensive. So to postpone the repair cost, just remove the front shaft for a while.
When you do replace the coupler make sure to also replace the bearing with it. |
#24 (permalink) | |
Schade
any idea where I can get the parts i need, cause land rover hawaii doesn't carry any of the necessary parts and claim they can't get any shipped to them... and thanks for the help. Last edited by schadeam : 07-12-2008 at 12:18 AM. Reason: more response.. |
| Thread Tools | |
| Display Modes | |
| Rear U-joint Driveshaft | DiscoAmigo | Discovery Series II | 1 | 08-03-2007 05:14 PM |
| Driveshaft rebuild | Steph | Discovery Series II | 10 | 02-28-2007 09:07 PM |
| U-joint | roverX | Discovery Series I | 2 | 03-22-2006 03:54 PM |
| Rubber disc that bolts to the driveshaft. | Hailsharky | General Land Rover Discussion | 10 | 10-11-2005 06:17 AM |
| SG front driveshaft for sale | doc1911 | Land Rover Parts and Accessories | 0 | 08-12-2004 06:17 PM |
