I have a 93 LWB.
I broke a front U-joint...actually, the yoke/flange holding the Ujoint...but that can be dealt with. The thing is...there is no power getting to the REAR either. The rear diff and driveshaft are intact. What about the center differential? Could that be it? Is there a way to lock it? |
Rebuilding Rover
On a 93 Range Rover it uses a vicious coupling unit to lock up. It's not user controlled.
It could be the transfer case has died on you. Oh and if you need a new yolk/flange contact paul grant here on LRO he probably has a few laying around. Great prices and a good guy to buy from.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
Rebuilding Rover
When you have the RRC up on jack stands at all four corners and put it in drive is the rear driveshaft turning?
If it is and the rear tires are not than you diff is blown or the axles are snapped. If it's not turning your transfer case is suspect. Oh and make sure your parking brake isn't set lol
#5 (permalink) | |
Ian Matthews
I will add one extra and suggest that you double check that the High/low range lever is not in neutral. |
Rebuilding Rover
Valid point I forgot to mention make sure the TC isn't in neutral
Okay. Thanks to super speedy and cheap service from Paul Grant, a new front driveshaft with ujoints is installed, and the car is driveable.
However...it seems there is no power getting to the rear wheels. I don't think the transfer case is in neutral, as power is getting to the front wheels. I don't know if it's the handbrake... When the car was hoisted onto the flatbed, I could see the rear driveshaft moving, so it's not the driveshaft or the rear axle and diff, I think. Which leaves, what? Transfer case only? Isin't there also a limited-slip deal on the front of the rear driveshaft? Could that be it? Labor-wise, what's involved in replacing the transfer case, if that's it? I don't want to go too far or too fast on just the front being driven, as I think that front driveshaft looks a little delicate to be moving the whole weight of the truck by itself! |
| Thread Tools | |
| Display Modes | |
| land rover drivetrain conversion ? | 1995RRCBURTON | Range Rover Classic | 1 | 09-15-2007 08:39 PM |
| RRC again with drivetrain issues...any ideas?? | TooSlowMonroe | Range Rover Classic | 9 | 04-15-2007 11:08 AM |
| troubles in life | 1st rover | The Lounge | 6 | 09-30-2005 02:45 PM |
| Clunking in drivetrain | Morgan | Freelander / LR2 | 1 | 07-15-2005 05:47 PM |
| RR Classic Drivetrain | simon285 | Range Rover Classic | 4 | 10-20-2004 05:39 AM |
