EAS high profile issues - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-25-2013, 07:43 PM   #1 (permalink)
Default EAS high profile issues
1993 swb with functioning air suspension-
I'm having issues with the truck lifting to high profile. It will go up and then drop back down within seconds. I can use the software on the computer to raise it very high and it will hold it overnight, so it's not a leak. I've got good air pressure and a good compressor. No fault codes either. Any suggestions of what to check?
I'm assuming I will get a slew of 'coil spring' comments
Kapnrover is offline   Reply With Quote
Old 01-27-2013, 11:25 AM   #2 (permalink)
1993 range rover lwb - Roman Bronze
ehojefua's Avatar
Forget the coils conversion.......have you tried resetting the whole system....I will tell you the sequence later on tonight when I get home........When I had my first classic back in '97 that was my issue and the mechanic reset it for me and gave me the sequence.....keep your EAS system...im thinking about swapping my coils for a EAS system
ehojefua is offline   Reply With Quote
Old 02-22-2013, 11:18 AM   #3 (permalink)
I got a minor issue on a ´93 LSE. When I turn the ignition off it sometimes decides to take the suspension down to Access level. No fault codes logged.
gunnar-rangerover is offline   Reply With Quote
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
P38 EAS unlock issues. English_Rugby Range Rover P38, Mk III and Range Rover Sport 2 09-29-2012 11:22 AM
EAS Issues '99 RR amyr61 Range Rover P38, Mk III and Range Rover Sport 1 08-28-2012 01:57 AM
newbie with EAS issues lwilliams1922 Range Rover Classic 0 08-15-2012 12:50 PM
EAS issues '99 RR amyr61 Range Rover Classic 3 07-21-2012 11:44 PM
95 RRC LWB Idle and eas issues petek19 Range Rover Classic 32 06-02-2012 08:02 PM
SEO by vBSEO 3.3.2
