Old 10-04-2006, 04:27 AM   #1 (permalink)
Default Ecu ?
Just curious.... is the 14CUX a direct swap for the 14CU in an 88RRC?? Or is there some wiring changes to be done?
Thanks!
Kevin
88 RRC "Audrey"
Old 10-04-2006, 03:08 PM   #2 (permalink)
I'd Rather Push a Landrover than Drive a Jeep
sevenrover's Avatar
Location: Durban, South Africa, 'til 2009. Then Back to Salt Lake.
I am pretty sure it is a direct swap, my brother has an 89 RRC and somehow the 14cu got some codes burnt into it that we couldn't erase, so he swapped it to a 14cux and it has run fine since.
1991 RRC
2 1989 RRC's
1998 RR P38A
1967 SIIA 88
1969 SIIA 88
1967 SII 109
1971 Vampire Radio Body 101FC
sevenrover is offline   Reply With Quote
Old 10-04-2006, 06:50 PM   #3 (permalink)
The 1988 ECU is not a 14CU. The 14CU was for 1989 and 13CU was used in 1987 & 1988. They are very different ECU's as the one for an '88 is a "flapper" style EFI while from '89 on the EFI was "hot wire."
