» Sponsors
» Sponsors
Old 11-02-2009, 05:37 AM   #1 (permalink)
ChamplianRover
Default Electrical Oddity
95 LWB.
Started noticing a quick electrical cutout at low idle. Symptoms:
1. Truck would almost stall during low idle, say pulling slowly into parking.
2. Noise through stereo (subwoofer would go "tonk")
3. At highway speed, very quick cutout and speedo would drop. I'm talking half a second.
Anyone have suggestions? Alternator would cause slow drain rather than split-second cutout, right?
Champlain Rover
ChamplainRover is offline   Reply With Quote
Old 11-02-2009, 06:54 AM   #2 (permalink)
This sounds more like a bad ground or battery connection than an alterntor issue.
Remove and clean the battery terminals, and inspect the wiring carfully. Look at the engine ground strap as well as the + batt term to the alternator.
You can get a free alternator test at most auto parts stores if you still suspect an alt problem.
Ken
kencary is offline   Reply With Quote
Electrical Oddity ChamplainRover Range Rover Classic 3 07-31-2009 02:04 PM
Electrical Fault John Discovery Series II 1 01-09-2009 08:23 AM
Electrical Ground points GentrysRover Discovery Series I 1 09-18-2005 06:58 PM
Electrical Problems Jumping Around MBailey Discovery Series I 17 05-11-2005 09:03 AM
Discovery I, 1997 Electrical Problem. May Day... Dmitri Lebedinski Discovery Series I 3 08-24-2004 08:23 PM
