Old 12-21-2007, 03:32 PM   #1 (permalink)
trellis8's Avatar
Default Electronic Traction Control light stays on.
I have a '93 RR LWB and it doesn't seem as if my front axle is engaging in ice and snow. The ETC warning light comes on and stays on. The ABS light also comes on. Help! We've been getting pounded with snow up here, I'd really like to get it working. Thanks, Brett.
trellis8 is offline   Reply With Quote
Old 12-21-2007, 07:47 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
More than likely a bad sensor.
I punch my clown daily.
Old 12-22-2007, 08:07 AM   #3 (permalink)
trellis8's Avatar
You mean a wheel sensor? Do you think it could have something to do with the ABS relay under the driver's seat? I'm lost, thanks!
Old 12-23-2007, 12:45 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
Yeah.
The wheel sensor can throw that code.
As well as a bad brake light switch.
And probably an ABS relay too.
You can tell if you can find an Autologic and plug that bad boy in. It will tell you which sensor is toast or throwing codes or if there is another issue present.
Old 12-23-2007, 01:26 PM   #5 (permalink)
trellis8's Avatar
Thank you, sir.
Traction Control Light Rioja Red Range Rover P38, Mk III and Range Rover Sport 0 11-13-2007 05:51 PM
traction control and downhill decent light on rovdog Discovery Series II 3 10-13-2007 12:05 PM
ABS and traction control light came on! Phlawed Discovery Series II 48 04-07-2006 02:04 AM
New Problem ABS, Traction control, Hill Descent Light came on smileyq Discovery Series II 13 03-24-2006 03:31 PM
ABS / Traction Control light problem (RR97) DanielS Range Rover P38, Mk III and Range Rover Sport 6 09-22-2005 10:11 AM
