I have an engine on the way (well as of tomorrow when I pay for it). Local shop wants $1500 plus an estimated $300 in unforeseen parts to do the swap. OkieRover says this job is hell. Anybody else done it? How bad was it for you? I am planning on getting everything to the point of hanking it out and then renting an engine hoist. Any tips?
Bill 93 LWB Westminster 155+k miles ArmyRover- "it's actually more of self inflicted torture chamber with doors and tires"- with this, I can relate! O Crap! decals - $3.00 to your door. |
Rebuilding Rover
1. Sacrifice 2 female virgins must be no older than 21.
2. For 2 weeks before the start of the project bang your head repeatedly against the front bumper this will serve to harden your head for when you get fustrated and start banging it against the wall 3. Buy the rover a full set of new tires always good to bribe it. Seriously label everything you disconnect take tons of pics bag all bolts and nuts and label them also take notes to go with the pics and labels above all else take your time when you get in a hurry is when you screw up and it's usually costly.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
Ian Matthews
Just completed one last week. Pulled out 2 motors, fully stripped one, partially stripped another, rebuilt partially stripped and refitted.
Just pulling one out and putting another in is probably a weekend's job |
The WORST part of the job are the bellhousing bolts. The ones one the upper side are so close to the bulkhead, you'll be talking to yourself.
#5 (permalink) | |
Ian Matthews
1) Remove the RUBBER engine mount and lower the motor so that it is just the two metal mounts resting on each other. This increases the working space to a useable level. 2) Get an old 9/16th spanner that you don't care too much about and bend it. Makes it a lot easy to use in the tight space. |
If the engine is coming out anyway, I've been told to remove the heads first to get to the top bellhousing bolts with more room. I'll be doing that on my '95 as I need to pull the tranny and do the headgaskets...
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (only the cab shell & rear bumper is original), '62 International 404 tractor (red & white) & many other project cars in the past! |
x2 on the bagging and labeling of stuff you remove, also taking lots of pic's.
It is not as hard as you may think to R&R a engine. Just be sure that you have everything you need before you start. Inspect and replace anything that could be damaging to your new engine or will be hard to get at once the engine is re-installed. Re-core your rad, for the money it costs to have it re-cored it is worth it. You don't want all that crap from your old rad running into your new engine. Try to get your engine out and the new one in as soon as possible. This way everything will still be fresh in your mind. Don't get it out and then call it a day, then get tied up doing something else. I did this once and 3 years later the engine is still sitting on the shop floor waiting for me to install it. Worst of all, I can't find half the crap I removed off the engine! As always a buddy, a six pack and a pizza make it more fun!
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969. |
#8 (permalink) | |
#9 (permalink) |
Take off the intake for the upper bolts. Install the engine without the intake to tighten them. Makes it SO much easier.
Bolt your chain to the intake bolt holes to get it back in.... Actually, as far as engines go, Classics are pretty easy to replace... Worst engine of my carrer to replace was a 95 Bonneville with a 3.8.... Jesus Christ that thing was aweful!
I only worry about myself, screw the others. |
#10 (permalink) |
A Ford V10, only 4 of the 10 cylinders are ahead of the windscreen!
A Jaguar V12....... need I say more!
#11 (permalink) | |
Ian Matthews
#12 (permalink) | |
#13 (permalink) |
What does the long block wiegh? I read through the manual and it does say to pull the motor mounts to ease access to the upper bell housing bolts. Going to pull the radiator today as a first step and hope to have the whole thing done over the course of two weeks. I already have plenty of pictures and all the wiring is still labeled from the head gasket replacement. Thanks, for all the response!
#14 (permalink) | |
What risk? Those holes arent any stronger then the ones for the intake. I have to have r&r'ed at least 30 Rover engines in my carrer and had zero failure doign it my way. I dont use the intake BOLTS, I use bolts with the same thread and hook them up in the holes.
