Old 10-08-2006, 07:10 PM   #1 (permalink)
Default engine swap 3.5 to 3.9
Hey all. I have a 87 RRC with the 3.5. For some resone my motor is only reading less than 50 PSI on all 8. It ran before I parked it, NOT NOW !! I have fuel to the rail , spark at the coil and to the plugs, timing is sat 6 BTDC with the rotor pointing at #1. Could my timing chain have jumped on me ?
I have another rover it is 91 with the 3.9 in it , it runs nice but the tranny is shot. Would it be a direct swap tp put the 3.9 in ? Does anyone know where I can find a write up ? Or online manual ?
I really liked this Rover , but this motor problem is kicking my butt ,any thoughts ? Thanks Corbit.
Corbit is offline   Reply With Quote
Old 10-08-2006, 09:25 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
The motors are a direct swap. No need for any instructions as they are the same for both motors. The fuel injection systems may be different, but whatever system you use will still bolt onto either motor.
Ian
Old 10-09-2006, 04:18 AM   #3 (permalink)
Your best bet is to pull the EFI harness from the '91 along with the motor. That way you can use the 14CUX ECU from the '91 in your '87. You'll get a much better injection system and the ability to read codes when you run into problems.
Old 10-09-2006, 09:31 AM   #4 (permalink)
Thanks for the responce's , I think putting the 3.9 in will be the way to go. I still dont know why my compression is reading so low , the motor ran OK , didn't smoke.
Old 10-10-2006, 12:47 PM   #5 (permalink)
good news , the compression tester was bad . Comp is up 150 PSI , but still no run. I have replaced the inherta switch , and ecu. I have fuel to the rail , I'll check fuel pressure today.
