Old 04-23-2008, 02:07 PM   #1 (permalink)
Default Engine ticking solved thanks to the Board
I have had an annoying engine ticking in my 95 LWB with 180K on the clock. I am a mechanical idiot but have reviewed the board with interest since getting this Rover, my 2nd LWB. Anyway, I figure the problem is with the lifters, and I tried a Sea Foam flush, no luck. I then tried 20/50 oil, a little luck, but not much. Once I burned off about a quart of oil (thanks to the marvels of the British engineering drip), I added some Lucas Oil Stabilizer. Bingo. Problem seems to be solved, or at least masked.
Anyway, I wanted to thank everyone for contributing. Much of the information goes right over my head, but the tips I got from here saved me from replacing (for now) the lifters and cam shaft, as one mechanic suggested, or replacing the entire enginge once this one blew up (which it still might do).
Thanks again.
pdolan is offline   Reply With Quote
Old 04-24-2008, 03:38 PM   #2 (permalink)
1989 county 3.9
i was astonished at how a different filter made my tappy lifters quiet. some filters start the oil pump dry where its prime is lost... it takes a while to get sufficient pressure to REALLY lubricate the top end. with the fram filter my lifters were tappy especially when cold. anyway, what kinda filter you runnin? its simple: better oil pressure from better filters. i replaced the fram with ac delco hd222 , they can also try to sell you a P series filter , but the HD is heavy duty with high capacity i think the P is cheaper and may stand for passenger vehicle.
i guess they use this filter on some Allison Heavy Machinery. anyway it made a big difference in lifter noise for me. NEVER BUY FRAM..
MysteryTheatre is offline   Reply With Quote
Old 04-24-2008, 05:07 PM   #3 (permalink)
roverthen's Avatar
Great info. First time I hear of this but it does make a lot of sense.
Abraham
1993 Range Rover Classic LWB
1995 Range Rover Classic LWB
I run, play, fix and live Rovers because I choose to.
roverthen is offline   Reply With Quote
engine ticking?? tbrisk Discovery Series II 7 04-26-2007 11:13 AM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
Ticking engine.... is it a time bomb? NiagaraRover Range Rover Classic 7 01-13-2006 07:28 PM
