engine vibration - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 43 (permalink) Old 03-25-2008, 04:31 PM Thread Starter
Quoted: 0 Post(s)
Unhappy engine vibration
to all, i have a 1995 rover classic with a 4.2 engine about a week 4 weeks ago i started to have a vibration in my motor. when diving the vibration varys in severity at all speeds. when parked the vibration seems the worse around 2-3 thousand rpm. i have tried everything i have changed the stepper motor, maf,ignition amplifier,coil,cap,rotor,wires,plugs,catalytic converters fuel filter and fuel pump and tank recall, checked my timing,air gap etc please help i dont know what else to do i am just about ready to sdismantle the motor thiking its internal the motor has 156,000 miles on it. please does somebody have an idea i have done tons of work and hate to give up thanks all
jsmolin is offline
post #2 of 43 (permalink) Old 03-25-2008, 04:33 PM
member
SafariDave's Avatar
Quoted: 14 Post(s)
What kind of gas do you use?
The City is a Jungle.
2005 LR3/ SE 4.4 Fancy Professor (my girl's LR3)
2005 LR3/Disco3 SE 4.4 The Rhino
(mine)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255 55 19"
1999 LR Disco II SD 200,900 miles (Sold)
1991 Range Rover Classic (Sold) 'The Turtle'
1988 Range Rover Classic (Sold) 'The Rust Bucket'
SafariDave is offline
post #3 of 43 (permalink) Old 03-25-2008, 04:46 PM Thread Starter
Quoted: 0 Post(s)
high test only thanks
jsmolin is offline
post #4 of 43 (permalink) Old 03-25-2008, 04:52 PM
member
SafariDave's Avatar
Quoted: 14 Post(s)
If you are in NY, you can take it to my LR guy he's amazing my engine purrs @ 185,000+ miles. He always has high mile RRC and keeps them going. Give him a call Ricardo is his name 718-274-5761. Good luck!
(mine)
post #5 of 43 (permalink) Old 03-26-2008, 09:42 AM
Life, Liberty, and the pursuit of Roverness
BullDogSix's Avatar
Quoted: 0 Post(s)
Is there a sound associated with this, or is it only "felt"? Possibly a harmonic balancer (up front on end of crankshaft)?? Does this vibration start after it's warmed up...or right from start up?
1998 Disco 50th Anniversary...#13 of 50
1971 Jaguar XJ6 SWB...resto in progress
1953 M38A1
...1994 RRC LWB...gone but not forgotten.
BullDogSix is offline
post #6 of 43 (permalink) Old 03-26-2008, 11:36 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 31 Post(s)
motor or tranny mounts?
1972 MGB
Coming Soon 2006 LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #7 of 43 (permalink) Old 03-26-2008, 11:44 AM
1989 county 3.9
Quoted: 0 Post(s)
there's not an engine in the world that doesn't vibrate at 2-3 thousand rpms.
if its accompanied by a metallic noise you have trouble.
otherwise i'd try to dampen the vibration by tightening the mounts. or replacing them if the rubbers shot.
MysteryTheatre is offline
post #8 of 43 (permalink) Old 03-26-2008, 04:25 PM Thread Starter
Quoted: 0 Post(s)
theres no noise with it and it comes and goes gets really bad and then less when driving and when parked it does it at idle and gets worse around 2-3 thousand rpm then less at higher rpms thanks
jsmolin is offline
post #9 of 43 (permalink) Old 03-26-2008, 04:25 PM Thread Starter
Quoted: 0 Post(s)
did not do this 3 weeks ago and no noise with vibration
jsmolin is offline
post #10 of 43 (permalink) Old 03-26-2008, 04:26 PM Thread Starter
Quoted: 0 Post(s)
checked mounts no probs there thanks
jsmolin is offline
post #11 of 43 (permalink) Old 03-26-2008, 04:27 PM Thread Starter
Quoted: 0 Post(s)
vibration only felt and is worse when warm thanks
jsmolin is offline
post #12 of 43 (permalink) Old 03-27-2008, 03:19 PM
1989 county 3.9
Quoted: 0 Post(s)
anything can cause a "vibration" : if the engine is misfiring... if one bank is running leaner than the other(o2 sensor), if one exhaust manifold is leaking and creating less back pressure than the other . it could be something as simple as fouled injectors , just going through and replacing hundreds of parts unfortunately does not neccesarily solve the problem, you need to find another clue.
what else besides "vibration"?.... you are only noticing it at idle more than when driving because the momentum of the moving vehicle pulls the engine through the "mis" and it is less noticeable. it sounds like an ignition miss maybe. take it out where it is pitch black and lift the hood while it is running, look for arching, cross-firing or grounding from the wires and distributor , you may just need a new dist cap or to re route some wires , maybe a wire came partially loose at the connector...
post #13 of 43 (permalink) Old 03-27-2008, 03:40 PM
Ian Matthews
p76rangie's Avatar
Quoted: 72 Post(s)
Check the engine (radiator) fan and water pump. Fans can go brittle and bits break off. The bits missing cause the fan to be out of balance and puts a viabration through the whole motor.
p76rangie is offline
post #14 of 43 (permalink) Old 03-28-2008, 02:21 AM Thread Starter
Quoted: 0 Post(s)
i have checked all injectors,wires,cap,rotor,plugs,even checked connections to injectors and ignition components
jsmolin is offline
post #15 of 43 (permalink) Old 03-28-2008, 03:13 PM
1989 county 3.9
Quoted: 0 Post(s)
sounds like that vibration your feeling is your engine running!!!!
without any other information from you i can only piss in the wind.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 57 12-03-2010 01:33 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
You may post new threads
You may post replies
