Old 01-21-2005, 07:46 AM   #1 (permalink)
OkieRover's Avatar
Gallery: 2
Default Error Code 14
After I completed the heater hose replacement. One of them sprung a leak. I now have an error code 14. That is the temperature sensor. But which one?
I thought I might have broken a wire but after repairing what I thought was broken I still have the error.
To clear the error another web page tells me to unplug the Serial mating plug. I can't find that anywhere in my manual.
Anyone have any ideas?
I punch my clown daily.
Old 01-21-2005, 09:30 AM   #2 (permalink)
hamrendan's Avatar
Maybe some coolant got out and into a connector, and crossed a wire or two/// I dont' think there is much in the way of wires on that side of the engine, but its a possibility...
Code 14 - Coolant sensor
Usually indicates a bad fuel injection coolant sensor. May also indicate a bad engine thermostat or a stuck viscous fan clutch. Refer to test 14, continuity test procedure.
Dan Hamren
93 LWB "Dubya" AKA "The Beast"
hamrendan is offline   Reply With Quote
Old 01-24-2005, 07:51 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
What is the Continuity test 14?
I can't find it anywhere.
Stuck viscious fan clutch? How do it know? It's meeee-kanical not electrical. How do it know?
