Old 01-05-2005, 07:57 PM   #1 (permalink)
Default Exhaust Heat Shield-Center Muffler
92 Rover Classic
What is the setup for the stock center muffler heat shield, to protect the floor?? Are there aftermarket units avaliable?? I recently had a hole in the top of the center muffler, and guess what, the carpet mat (foam or rubber mat) under the rear floor carpet melts,smokes and smells really bad. Is there a solution for this potential "hot problem"??
Irvin is offline   Reply With Quote
Old 01-06-2005, 06:23 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
Originally Posted by Irvin
92 Rover Classic
I've heard of some folks going to Home Depot or Lowe's and purchasing a piece of alluminum (or some metal sheet) and attaching it to the top of the muffler. The original heat shields are over $70 (jeesh).
Why not replace the muffler at a local Midas shop? I have a flowmaster muffler and a straight pipe in the rear section and it's really not that loud.
Good luck,
John C.
Old 01-07-2005, 09:56 AM   #3 (permalink)
hermanpj's Avatar
Gallery: 4
i agree. that resonator can on the end of the tailpipe does virtually nothing.
Pat Herman
Old 01-08-2005, 05:47 AM   #4 (permalink)
Default John C
Good luck,
John C.
THanks for the info. I've had the center muffler replaced, in fact the center muffler was a lifetime warranty stainless unit. I'm worried about future problems and general summer heat plus hot exhaust getting north into passenger compartment. I did more research and found that Atlantic British has a $59 replacement. Thanks!!
Old 01-15-2005, 10:48 PM   #5 (permalink)
Just replaced the same part on my 95' LWB - ordered mine from Atlantic British as well. Good luck - definitely need one, rear carpet will start to burn otherwise
NJRover is offline   Reply With Quote
